Thermocoupler help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-16-2008, 06:21 PM Thread Starter
Thermocoupler help
Does anyone know what size drill bit, and tap I need for the r658S thermocoupler. I didnt get the guages form diesel manor, but tried to use theres, and they said use 1/8th inch and I know thats wrong just looking at it, looks more like half inch, thanks!
or apparently 1/8th npt is the threads, what size tap should I buy, thanks!
dayusex is offline
post #2 of 7 Old 07-16-2008, 06:29 PM
Gmclbz's Avatar
I believe 11/32s is the size you need, which is just over 5/16s.
11.77 @ 114
Gmclbz is offline
post #3 of 7 Old 07-16-2008, 06:37 PM Thread Starter
is 11/32 the tap or drill size?
dayusex is offline
post #4 of 7 Old 07-16-2008, 09:26 PM Thread Starter
So I bought a 1/2 inch tap. I put a 1/2 nut on the end of the thermo coupler and it fit snuggly.
Is this correct before i start drilling??
dayusex is offline
post #5 of 7 Old 07-16-2008, 10:17 PM
william_04_x's Avatar
you might want to triple check before you drill...1/8" NPT is very common for thermocouples..i don't know what you have though...
04 EB X w/03 6.0l PSD
william_04_x is offline
post #6 of 7 Old 07-16-2008, 10:19 PM
do the threads on the TC match? both fine or course? usually they're fine threads..an 1/8" NPT tap is larger than an 1/8 of an inch..
post #7 of 7 Old 07-16-2008, 10:25 PM Thread Starter
i have course threads, ill try to post a pic tonight
dayusex is offline
