6.0 Hard Acceleration Problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-18-2013, 03:09 PM Thread Starter
I recently bought a 2005 Ford F250 with the 6.0, truck has 105k miles on it. Air raid cold air intake, 4" MBRP exhaust, with no cat. Other then that the truck is stock motor wise. The problem i have been having, is when at a stop light or starting from a stopped position, when i put the pedal to the floor it dumps a huge amount of black smoke, and almost has a leg take off. Once at speed, the truck runs fine and accelerates just fine. To me, its like the truck is getting to much fuel dumped to it at lower RPMs. Also this past weekend, i went to climb a hill from being stopped, and when i accelerated the motor would load up and do nothing but dump a huge cloud of black smoke and wouldn't move anywhere. I took the truck to AutoZone today and the truck isn't throwing any trouble codes. This is my first diesel i have owned, and am looking for some help on trying to diagnose whats wrong with my truck.
Thanks!
WoodHoodDiesel213
WoodHoodDiesel213 is offline
post #2 of 6 Old 10-18-2013, 03:13 PM
powerstrokecrzy's Avatar
Quoted: 264 Post(s)
Sounds like vanes in the turbo are sticking. Plenty of how to's our there on how to clean, look youtube.
Are you sure the previous owner didn't have a programmer on it and left it programmed when you bought.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #3 of 6 Old 10-18-2013, 03:14 PM
05krsd's Avatar
Are you sure the previous owner didn't have any more work done to it?
2005 F250 King Ranch, CCSB, FX4, 4.5 inch rough country lift, Edge Evolution tuner, studded, nitto terra grapplers 35s, custom exhaust, intake, hids. SOLD.
Looking for my next powerstroke.
05krsd is offline
post #4 of 6 Old 10-18-2013, 03:20 PM Thread Starter
I bought it from a dealership, and they said no other work was done to it. I have not checked if it had a programer on it before, whats the easiest way to checkfor that? Thanks for the quick replys!
post #5 of 6 Old 10-18-2013, 04:25 PM Thread Starter
One other thing, the truck is a lariet so it has the 4 AUX switchs. One of the switches when turned on idols the truckup to about 1200 RPM. Is this for warm up?
post #6 of 6 Old 10-18-2013, 04:33 PM
f250ghost's Avatar
That's just a high idle switch...actually a nice thing to have. I use it whenever it's cold in the winter to warm the truck up a little quicker...or if I'm gonna leave the truck idling for a long time I'll hit the high idle switch
-Ben
2011 F250 FX4
6.7 PowerStroke
f250ghost is offline
