GAUGES - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-18-2013, 01:27 PM Thread Starter
GAUGES
HI LOOKING TO GET GAUGE'S FOR MY TRUCK.I NO TO GET THE EGT BOOST AND CAN SOMEONE LET ME NO WHAT IS THE MOST NEEDED AS FOR THE 3RD ONE? THANKS FOR THE HELP.
kchast is offline
post #2 of 7 Old 10-18-2013, 01:36 PM
Raul@Stealth Automotive's Avatar
trans temp.....
Raul@Stealth Automotive is offline
post #3 of 7 Old 10-18-2013, 01:59 PM
1fastTRX's Avatar
Fuel pressure
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #4 of 7 Old 10-18-2013, 02:20 PM
Depends on your Transmission, automatic run a Trans. temp gauge, if you are ZF-6 I would suggest fuel pressure, HPOP, or Oil Temp.
PDRdiesel_matt is offline
post #5 of 7 Old 10-18-2013, 04:13 PM Thread Starter
MY IS THE 03 6.0 THANKS FOR THE HELP
kchast is offline
post #6 of 7 Old 10-18-2013, 04:14 PM Thread Starter
AUTO TRANS
kchast is offline
post #7 of 7 Old 10-18-2013, 04:24 PM
USAFBowman's Avatar
Coolant Temp, Oil Temp, EGT, Boost, Trans Temp
I would suggest getting a monitor such as the Edge Insight CTS or the SCT Livewire for "gauges"
USAFBowman is offline
