EGR and EGTs - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-14-2008, 05:11 PM Thread Starter
snoboy's Avatar
EGR and EGTs
OK I have come to the conclusion that some EGR leaks past the valve even though it has an SCT command off. Ever since I installed the EGR slug my EGTs will hit 1200 deg.
When hauling my camper over the pass unless I kicked it down to obtain over 20lbs. of boost the EGTs began climbing to 1200. I pulled over and swapped out a 50 hp tune for a 40 hp tune and same thing happened. I pulled over and returned to stock and only then could I barely keep under 1200 deg. I will say this though... stock tune w/ DJs fuel system, big mouth CFM, 4.30 gears and a slugged EGR the truck will haul the mail. Truck feels like it has a 30hp tune setup like this.
So my dillema is...
1) leave stock when hauling weight.
2) Reinstall EGR and an SCT tune.
3) Adjust shifting somehow so truck will hold 4th gear longer and allow me to put the boost to it so EGT stays comfortable (1150 on long pulls).
Any input?
snoboy
-2003 F350 6.0 Fx4 Lariat w CLOUDRIDER grill
-12/02 build
-Toyo Open Country AT2 Xtremes 285/75/18
-4.30 gearing
-SCT current tune: Quick Tricks 40hp tow w/ Jake Brake
-Banks turbo back exhaust
-CFM+ largemouth intake kit
-DJs Fuel Intensifier
-Dieselsite coolant filter
-BD Diesel CCV filter
-Fumoto drain
-Autometer Cobalts in woodgrain pillars.
-Powerslot Cryo rotors & Hawk LTS pads
-KYB Monomax & Ride-rite airbags
snoboy is offline
post #2 of 8 Old 07-14-2008, 05:40 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
1200 EGT temp is nothing to be scared of. You're not gonna melt pistons at that temp, just don't keep it there all day. I'm not sure what you mean by EGR slug, but unless the EGR valve is welded shut, it will leak by under high boost. It takes no effort with a finger to open an EGR valve. Your EGT's can be controlled by your right foot.......that's what the gauge is for. You need to try one of the Frog's tow tunes. They are the stuff!
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #3 of 8 Old 07-14-2008, 05:51 PM
Gmclbz's Avatar
X2!
11.77 @ 114
Gmclbz is offline
post #4 of 8 Old 07-14-2008, 05:57 PM
Send a message via AIM to Biofuelsdude
My suggestion, if this persists and bothers you over time, is to get a snow performance water injection kit. Not only will it kill your EGT's under high load but it may also add to increased mileage. Here is their website and I do not work for them or get any money for doing this Snow Performance: Products
The seven gallon stage III kit would work well for long hauls as well as keeping refills down to a minimum. Stock up now ,in the summer, on windshield wiper fluid before prices go up in light of the winter season.
Erik
Biofuelsdude is offline
post #5 of 8 Old 07-14-2008, 06:51 PM Thread Starter
snoboy's Avatar
OK I realize I control my EGTs with foot english. The problem is having to back out of it to allow EGTs to drop I'm losing speed. If I kick it down then I can get enough boost rolling to help cool the EGTs (I no longer have an EGR valve, I have a slug in the hole same as welding it shut). The problem is when I kick it down it'll run up to the shift point, upshift to OD again, boost will drop into the teens and then EGTs will start to climb. BTW 1200 is MY stopping point, I have no doubt the EGTs would just continue to climb into the danger zone. As far as a new tune, I already have 12 different custom tunes from DJs, Spartans, and Innovative everthing from 20 to 160 hp. A new tune is not whats needed. I see you guys live in NC, New York and Ill. I'm not sure about upstate New York but I've been to ILL. and NC and I'm not dealing with that type of terrain. I'm dealing with 8% grades that are 30 miles long.
Biofuelsdude I was thinking of water/alcohol injection this my whole trip home today as a possibility. My CFM bigmouth already has threaded ports in it.
-12/02 build
-4.30 gearing
-Fumoto drain
snoboy is offline
post #6 of 8 Old 07-14-2008, 07:52 PM
Hey dude,
I feel you on getting up there with your EGT's. 1200 goes to scary fast if something indeed does go wrong or it becomes a crazy hot day in August. All in all, I think the melting point is 1500 F or 1600 F? I'm not sure on the "danger zone" so any correction is more than welcomed!
Fighting EGT's can also be done with biodiesel because it does not burn as fast. IE. a higher cetane value. It takes longer to explode and thus causes 1. more nitrogen emissions and 2. decreases sound of the detonation. First and for most I say you go with the stage 3 kit from snow performance. If you are doing 30 mile pulls up a 8% grade, then 7 gallons should last you awhile. Your call buddy. Other options are propane fumigation, CO2 injection on the intercooler, or Nitrous oxide injection. However, I personally do not like compressed gasses on board and would feel safer with a water injection kit.
Erik
post #7 of 8 Old 07-15-2008, 06:07 PM
Quoted: 5 Post(s)
ok.....your EGR valve is deleted, but is the EGR cooler deleted or closed off from exhaust gas also? That's another consideration on superheating your coolant. Yes, I live in NC, but there are still some pretty good grades here, although not 30 miles long, and I understand where you're going with the EGT thing. I'd be highly in favor of the water injection kit. It will greatly help with your EGT's for sure and will even help with your mileage. Your only other option is to increase your turbo size or get a bigger intercooler or both and get more air in the hole. How much weight are you towing up those grades???
post #8 of 8 Old 07-15-2008, 11:02 PM Thread Starter
snoboy's Avatar
No the EGR cooler is in place. But i'm not having a coolant issue only EGTs and I did not have any issues until I installed the EGR slug. I tow/haul anything from 6500-10000 lbs. Heck it's not even an issue until the hill starts getting 6%+ and long. I'm seriously considering just putting the valve back in and running my 50 hp tow tune. The valve must pass just enough exhaust gas (at high boost levels)to cool the EGTs but not hurt hp too much.
-12/02 build
-4.30 gearing
-Fumoto drain
snoboy is offline
