k&n intake question... - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-14-2008, 04:17 PM Thread Starter
twitchvoodoo's Avatar
Hey guys whats up.... Just a quick question, my buddy gave me a new k&n air intake system and we installed it and it works great, just wondering if anyone has had any problems with it that i should know about, I dont have head studs or anything either??? And another question how exactly do you gut a cat. and what exactly does it gain for your truck.. Thanks in advanced....
2007 F-250 Fx4, Pro-comp 2.5 leveling kit.Stock intake 4in cat back exhaust kitty and muff ran away,MTX 600W AMP 2 10in shallow Kicker cvt subs, custom sub box, zoodad, High Idle mod, 34inch BFG ko ATs, N-Fab Pre-runner lightbar,5 6in.lights Train horn
twitchvoodoo is offline
post #2 of 18 Old 07-14-2008, 05:50 PM Thread Starter
Anybody please help
post #3 of 18 Old 07-14-2008, 05:52 PM
farmboypowerstroke's Avatar
you got the k&N filter on there too?
farmboypowerstroke is offline
post #4 of 18 Old 07-14-2008, 05:52 PM
Gmclbz's Avatar
It would probably be alot easier to buy a cat delete pipe.
11.77 @ 114
Gmclbz is offline
post #5 of 18 Old 07-14-2008, 05:53 PM
duct tape & zip ties
bigcountrysg's Avatar
Replace the K&N intake with different brand.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #6 of 18 Old 07-14-2008, 05:56 PM Thread Starter
what do you mean replace the filter only or the whole kit??? and if so what filter can i use
post #7 of 18 Old 07-14-2008, 05:57 PM
DunesRunner08's Avatar
K&N sucks a$$...... as for gutting a cat...its a PITA so just buy a delete pipe or buy a turba back exhaust setup....the gains is less back pressure for more HP and TQ as well as lower EGT's
Beware!!!! The King Has Returned
DunesRunner08 is offline
post #8 of 18 Old 07-14-2008, 06:04 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
The stock filter is MUCH MUCH better than the K&N and will handle MORE than the stock turbo can ask of it. Get a delete pipe and save your CAT. You may need it in a year or two. Not to mention the scrap price is outrageous for those things.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #9 of 18 Old 07-14-2008, 07:31 PM
Rice Hunter
Diesel Freak's Avatar
I'd have to agree with saving that cat instead of gutting it. (way too much trouble). Replace with pipe. Flows/sounds better and lowers EGT's slightly.
As far as the K&N ..... some have complained of turbo dusting. I personally think some were not installed correctly. Drop-ins have had the biggest issues. I pull my hose off and check turbo every oil change. I think some hose clamps get loose. Use air ratchet and not screw driver to TIGHTEN THOSE HOSE CLAMPS GOOD!!
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #10 of 18 Old 07-14-2008, 07:44 PM
Diesel Freak does this look like it is installed improperly. Nope sure doesn't to me. But what I do see is holes. What are those holes from sand. Where did the sand come from the sand dunes I went to for a weekend.
Now yes the filter is grey. That is because I was cleaning it when I discovered the holes. I called K&N and they asked me to email pictures to them. I informed them that I discovered the holes when cleaning the filter, I told them that it was not oiled. They said no problem they just need the pictures to verfiy that is a K&N and then they would warranty it. Now K&N did over night me a new filter. But I still replaced it with the TYmar filter. At least until I can find a new aftermarket filter intake I like.
2002 7.3L burnt
