ll THE ll $50 ll OR ll LESS ll EGR ll DELETE ll - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-16-2013, 09:37 PM Thread Starter
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Hopefully this can help some people save some money and gain a little confidence/learn something about their truck.
This is what you can do on an OEM configuration, buy a 1/2" NPT tap, 1/2" NPT pipe plug, 5/8" steel "T", 1' of 5/8" coolant hose and an EGR up pipe block off plate. Then tap the front cover, plug it, then return the coolant from the oil cooler to the "T" into the heater core return. Then all you have to do is take the 1/4" cooling hose from the intake out and "T" it into the 1/4" radiator return line and cap the other nipple on the degas bottle with the open end. Less than $50 and your in business.
For a BPD configuration you can remove the brass coolant fitting and simply install a 1/2" NPT pipe plug instead of routing the coolant to the heater core return. You could also run IPR's high flow coolant filter in lieu of blocking (BPD) or rerouting the coolant (OEM/BPD).
Also you could cut the scoop out of the EGR up pipe (only certain MY's are applicable -scoop-) and weld a patch over the hole in lieu of placing a v-band plug over the EGR outlet.
You can kind of see the foot in this pic. I'll try to get a better shot tomorrow.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #2 of 8 Old 10-16-2013, 09:50 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 835 Post(s)
Feedback Score: 6 reviews
Hmmmmmm..... Sounds very tempting. Have any pics Bryan?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 8 Old 10-16-2013, 09:53 PM Thread Starter
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Did it on mine and a few customer trucks with zero issues reported back. I have an EGR up pipe delete in mine though so that's not included in the $50. Should one choose to go that route several vendors have just that pipe available for around $75 shipped.
I believe I have a few of the valley. My intake manifold is different from yours so my front cover is plugged by a foot welded to the bottom of it. Serves the same purpose on mine as the plug would on others. I have used the plug in other trucks though and it does work. Let me see what I can dig up.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 8 Old 10-16-2013, 10:06 PM Thread Starter
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Pics are up.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 8 Old 11-08-2013, 02:18 PM
Newbie question...would this cause any issues on a stock truck w/o a tuner?
BlackBy4 is offline
post #6 of 8 Old 12-09-2013, 02:11 PM
ryaninman's Avatar
Garage
Am I correct in saying that this leaves the cooler in place to keep the intake sealed?
Also, what are you thoughts on the up pipe delete tube you run? I've read there is a concern about the absence of the flex pipe found in the stock unit causing the Y-pipe to crack. I've also read that it's a bad idea to use a stock up pipe (w/o scoop) if it's not supported by the EGR cooler.
I want to get rid of the EGR cooler, too (with the BPD oil cooler install) but to leave the useless appendage in there goes against all of my OCD tendencies.
Ryan
2003 Excursion 4x4
Atlas 40 Tune from FICMRepair.com
DC Power 185 Amp Alternator
Flo~Pro 4" Turbo Back Exhaust
DashBoss PowerStroke Bundle
CT Performance Suspension
BMF Novakane 20x10 / Toyo AT II 295/65/20
ryaninman is offline
post #7 of 8 Old 12-10-2013, 04:48 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
Also just for another option, you can use a 3/4" freeze plug in the front cover...that way there's no metal shavings from tapping it to worry about in your cooling system. The 3/4" freeze plug drives in really easy, good press fit. That's how I just did mine for a ported intake with the egr totally deleted. That would save even more money, freeze plugs are less than a dollar and don't need a tap.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
The Following 2 Users Say Thank You to Gearhead2012 For This Useful Post:
Merc82 (12-13-2013), Tuscany (12-10-2013)
post #8 of 8 Old 12-10-2013, 04:12 PM
strokin6L's Avatar
Quoted: 3 Post(s)
Yeah the freeze plug would be better. I've heard of some guys doing the freeze plug with zero issues.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
