EGR Delete with BPD oil cooler - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-16-2013, 06:54 PM Thread Starter
PowerStrokedRedneck's Avatar
I have an 05 Ex. I would like to do an EGR delete. I also want to do the BPD oil cooler but don't have the cash right now for it. I have heard that there are only a few deletes that will work with the cooler. Does anyone know which ones? Would also like some input on which deletes you guys are running and how they worked for you. Thanks.
Sent from AutoGuide.com App
PowerStrokedRedneck is offline
post #2 of 4 Old 10-16-2013, 08:12 PM
portcity_gt's Avatar
Quoted: 1459 Post(s)
You have it backwards. ....ANY egr delete will work with it EXCEPT the ipr gen II delete.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 4 Old 10-16-2013, 08:26 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
This is what you can do on an OEM configuration, buy a 1/2" NPT tap, 1/2" NPT pipe plug, 5/8" steel "T", 1' of 5/8" coolant hose and a up pipe block off plate. Then tap the front cover, plug it, then return the coolant from the oil cooler to the "T" into the heater core return. Then all you have to do is take the 1/4" cooling hose from the intake out and "T" it into the 1/4" radiator return line and cap the other nipple on the degas bottle with the open end. Less than $50 and your in business. For a BPD configuration you can remove the brass coolant fitting and simply install a 1/2" NPT pipe plug instead of routing the coolant to the heater core return. You could also run IPR's high flow coolant filter in lieu of blocking or rerouting the coolant.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 4 Old 10-17-2013, 02:34 AM
Snake's Avatar
Quoted: 47 Post(s)
This
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
