Snow performance Water/Meth Questions - Ford Powerstroke Diesel Forum
post #1 of 25 Old 10-16-2013, 01:36 PM Thread Starter
paintballbryce's Avatar
Hi there,
Installed my kit somewhat last night at around 10pm, So I never got it all done due to not enough light, and I had a couple questions, hoping someone could clue in and help me out. I was wondering if its possible to use one of my aux switches for the switch for the water/methanol system, and secondly, where the black hose coming out of the control box that says Boost input goes into. Instructions that came with it aren't the best!
Thanks!
Bryce
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
post #2 of 25 Old 10-16-2013, 01:38 PM
Gun Nut
Rodslinger's Avatar
Quoted: 149 Post(s)
Originally Posted by paintballbryce View Post
Hi there,
Thanks!
Bryce
What model do you have? I've had a Stage 3 for years and yes I used a toggle for it.
'05 F250, CC, FX4, 6.0 PSD
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Please support our troops!
Rodslinger is offline
post #3 of 25 Old 10-16-2013, 01:45 PM Thread Starter
I have stage 2, Did you use the aux switch that is an option in our trucks or your own? I was hoping to utilize the ones that I already have that came from the factory if it was possible.
Stock for now
post #4 of 25 Old 10-16-2013, 01:49 PM
Gun Nut
Rodslinger's Avatar
Quoted: 149 Post(s)
I used one of the factory toggles. Works GREAT.
Hey can you tell me where those two red wires that go into the solenoid (I guess that's what it is) that's not in the instructions go? I took mine off awhile back and never marked where those two damn wires went.
SO it's mounted and not hooked up.
post #5 of 25 Old 10-16-2013, 01:52 PM
Gun Nut
Rodslinger's Avatar
Quoted: 149 Post(s)
Oh and I'll look but as I recall the black BOOST hose you T-off of your boost gauge.
post #6 of 25 Old 10-16-2013, 01:58 PM Thread Starter
How did you access the switch? Add a circuit? And I just have the pump, tank and control box. Don't have an external solenoid on my kit! And the black hose looks like it's for air or a liquid, but it has a white barbed T that I think goes in the end and I'm guessing is how it measures the boost but it's got me stumped on where it splices into
Stock for now
post #7 of 25 Old 10-16-2013, 02:14 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The hose goes to boost line. Your gonna cut the MAP hose going form the intake manifold to the MAP sensor, then just "T" it in.
After you "T" the hose in, and the hose's are on, use cable ties to secure the hose to the barbed "T".
That hose going to the control box is what Snow uses to read your boost, so you can adjust the W/M to come "on" and progress the injection as boost increases.
I don't have factory upfitter switches (04 truck), so I uses a laminated toggle switch.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #8 of 25 Old 10-16-2013, 02:15 PM
Gun Nut
Rodslinger's Avatar
Quoted: 149 Post(s)
Is this near the same setup you have?
post #9 of 25 Old 10-16-2013, 03:03 PM Thread Starter
Yes its similar mine just looks newer, and map tube goes from mid engine to the passenger side up beside the sensor, correct? My hose looks a lot bigger then what the snow performance t that came with the kit, and mine had a plastic cover on it so I just want to make sure!
Thanks!
Stock for now
post #10 of 25 Old 10-16-2013, 03:36 PM
Powerstroke Techie
Lilpooh's Avatar
Yes, MAP hose goes from pass side intake manifold to sensor. In first pic, I changed out my factory MAP hose to a red hose. Second pic, is where the MAP sensor is, behind the bracket that I'm pointing at.
Lilpooh is offline
