Head Gaskets & which SCT - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-13-2008, 07:13 PM Thread Starter
sand41's Avatar
Hey Guys,
Newbee here and I have a couple questions.
I'm considering the purchase of a programer and after reading some of the threads in the forum I'm some what unsure if I really want one; question is
does the result of blown gaskets happen over a period of time due to a heavy foot or can it happen any time? I'm not a heavy foot driver but I would like a few more hp from time to time when I need it.
I've been doing a lot of reading on this forum and was looking hard at the SCT, I plan on using just the loaded tunes unless down the road I decide I need something more than the three tunes.
I have an 05 F250 6.0 and a 06 F150 5.4 and if I read it correctly the X3 will work on both trucks question is will it load both trucks?
Any suggestions or help I would really appreciate.
Thanks
sand41 is offline
post #2 of 13 Old 07-13-2008, 07:18 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
Will work on both, but will have to be "unlocked" with each switch to other truck. Only have 5 unlocks on programmer. Now that is with the Xcal2s, I think it's the same with the 3s. Also, you would have to put the other truck back to flstock setting.
As for studs...it can happen to any of them. Not as common with running it stock though. But, if you go with custom tunes, the tuner can make a program that you will enjoy with more power, yet still be safe to run on factory bolts.
Oh, and
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
post #3 of 13 Old 07-13-2008, 07:22 PM
Rice Hunter
Diesel Freak's Avatar
+1 with what Eric said
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #4 of 13 Old 07-13-2008, 07:23 PM Thread Starter
sand41's Avatar
Are you saying the can tunes are stock and custom are other than the can tunes?
sand41 is offline
post #5 of 13 Old 07-13-2008, 07:25 PM
Dusty's Diesel's Avatar
The biggest benifet to the custom tunes is the tranny tunes, your tranny will appriciate the custom tunes alot better than the canned tunes. Garenteed
Dusty's Diesel is offline
post #6 of 13 Old 07-13-2008, 07:26 PM
canned tunes come on the tuner and custom tunes are wrote for you specific truck, by a tuner like Eric @ inovated.
post #7 of 13 Old 07-13-2008, 07:26 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
Yes, canned tunes are just that. Generic written files for any/all 6.0s.
Customs are written for your truck, strategy, driving style, wants/needs, and mods (if any done).
Eric
Email:
DKR is offline
post #8 of 13 Old 07-13-2008, 07:31 PM Thread Starter
sand41's Avatar
Ok I think I understand now, a tuner can custom a tune for my needs taking out some of the risk of poping headbolts.
sand41 is offline
post #9 of 13 Old 07-13-2008, 07:33 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
Exactly!
Unfortunatly, the risk will always be there, greatly reduced though with a proper tune. Biggest thing is the timing set by the program, but with a reputable tuner written files, it will be the safest option for gaining more power.
Eric
Email:
DKR is offline
post #10 of 13 Old 07-13-2008, 07:36 PM Thread Starter
sand41's Avatar
Thanks guys,
I feel a little better about this.
Any suggestions from who to purchase a SCT 3 from?
Thanks again.
sand41 is offline
