aftermarket torque converter - Ford Powerstroke Diesel Forum
post #1 of 26 Old 10-16-2013, 10:24 AM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
I searched and couldn't really find much. But wanna do a converter next year. Looking to do a PI converter. What I'd like to know is....what kind of improvements will a heavy duty aftermarket converter make? For those that have done one and nothing else at the same time of install....what did you notice after install when driving? Thanks!
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #2 of 26 Old 10-16-2013, 03:15 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
My PI is in its box in the living so I have no data for you. I can tell you it is physically larger than the stock converter by about an 1".
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #3 of 26 Old 10-16-2013, 03:19 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
While I haven't installed one on my truck as of yet you should see faster firmer lockup as well as the durability to handle higher hp and torque. With a better lock up the converter is more effectively able to multiply torque coming through the engine to the trans thus allowing you to better put the power to the ground. Also less slipping lol.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 26 Old 10-16-2013, 06:49 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
I've read with good converters, really efficient ones, you get that lock up feeling even when not locked. I have a PATC triple disc sitting in my kitchen waiting the trans to get back from Andy warren. If I were smarter, I would have planned better and probably went with a PI from either Brian at BTS, 1600 rpm stall instead of stock-ish 1800-2000, or a PI from Andy. I haven't used my PATC yet, I certainly don't have any complaints yet...i just know the PI stallion is very proven. Mitch is running a PATC converter, said he's very happy with it...he went in on it with me. They're normally 900, but if you buy 2 then they're 700 each. I ordered mine and mitch's right from PATC, but I think Gary shuck is a dealer for them. I say better planning because I had a used transmission I was going to swap in with a new converter to buy me time to build mine that came out, so pressed for cash I went with the best billet converter for the money I could find. I would have maybe liked to have spent a couple hundred more on the PI...but again, i havent run my patc yet. Ill let you know hopefully next week how it does.
The whole idea behind billet is that it will distort less under load, when it distorts it leads to uneven clutch clamping load which smokes the converter. Also...you could swap to a 6.4 flex plate and run a 8 lug/stud converter instead of a 6 stud like the 6.0 has. They make billet flex plates...but they're like 700 bucks.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #5 of 26 Old 10-16-2013, 07:21 PM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
Definitely let me know what you notice after the install. Eric at ID said it'll knock a few tenths off in the 1/4. But I'm not so much interested what it'll do for the 1/4....more interested what it'll do and what improvement there'll be daily driving than the stocker
post #6 of 26 Old 10-16-2013, 08:41 PM
Quoted: 10 Post(s)
I'm gonna throw this out there and I've already briefed Chris about this:
Buying a PI converter from anyone other than PI is just silly in my opinion. PI offers great deals and if you ever have a warranty related issue, the vendor you purchase it from is going to make you deal with PI. They're not going to deal with it. One of my 6.4 buddies just went through that with RCD. He bought a RCD converter (a PI converter with RCD's name/color). He had issues and RCD made it go straight to PI. Absolutely no reason for a middle man, at least not in this case, especially when PI offers decent pricing.
Now, lets talk about billet flex plates. Flex plates are designed by nature, to flex. Yup, that's right, they flex. Think about how the flex plate/converter/crankshaft all work. Something has to be the soft spot or "weak link" or you're going to break stuff and in this case you could break all three of those items I listed. The idea behind having billet components is to prevent them from breaking. Well, if it boils down to the converter/pump, flex plate or crankshaft, I can tell you which one I'd like to replace. The concept of the billet flex plate is a good one but in reality, it's not the best idea. It has to flex under high torque loads/demands or something else is going to give.
Shack
post #7 of 26 Old 10-16-2013, 08:56 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
WELL SAID.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 26 Old 10-17-2013, 03:23 AM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
I knew all about PI's warranty and how it works years ago when I talked to them about a converter for my truck. However I won't be dealing with them directly...I'll be dealing with Warren as they will be the ones installing it. If there is an issue or the stall needs to get changed...I have no problem calling PI about it...that's not a big deal. But if there is an issue....the truck is going back to warren to get fixed anyways.
post #9 of 26 Old 10-17-2013, 12:37 PM
Quoted: 2 Post(s)
Talking about the converters, and where you buy them from...some places like Brian at bts (and lots of others...probably andy and rcd have their specs too, i didnt talk with andy much about torque converters because i already had a brand new one) have their specs they have them built to...unless you knew what specs to tell them there wouldn't really be a way to get their converter with those specs...stall speed, ect. Plus some places offer different warranties depending on whether or not you buy everything from them. Twisted diesel told me if I ran my converter it wouldn't be the same warranty as if I had bought the whole package from them. It means having a middle man, but sometimes its worth it...all depends on who you deal with. Just other things to consider, advantages/disadvantages both ways in going directly to the source or not.
Under construction
Machining the 6.0:
post #10 of 26 Old 10-19-2013, 09:19 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
can you swap a 6.4 flexplate stock for stock into a 6.0? what about the stock 6.4 torque convertor in a 6.0? any input?
I am going to look for a 09-10 6.4 trans for my truck but I don't know how exactly everything would fit up.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
