confused egr?
ok i have all the stuff in my sig now i keep seeing the other problem is the egr cooler or egr.....dont know im in the gray about this .....i know they sell a block off plate for the 03 ...and ive been hearing that i can get the tunes to turn it off
ok so what do i need to do can someone shed some light on this for me ......
nice sig lol it looks kinda like mine. but i believe dj's can write a tune for when u block it off. i'm not exactly sure how to do it or how hard it is but i am in the same situation as u i would like to know some more info on how to go about blocking it and messing w/ tunes
you need to get a block off plate or sneaky pipe. plate is like 20 dollars and a sneaky pipe im not to sure of. i know a few vendors around here sell em. but as for the sct tunes turning it off thats for the computer. you still have to block the egr valve becuase it can still be pushed open through pressure if its not blocked even if it is turned off through tunes
Get special tunes to turn off sct. Weld EGR valve shut. Block off up-pipe to keep hot air from dead heading cooler.
Or just buy a complete delete kit!
where can i get a complete delete kit
complete delete is the best way to go, but you can block it off for about $1 and a few hours worth of work. I used a freeze plug I got at the parts store for under $1(I think the actual part number is on this site) I'll see if I can find it. and then weld the valve shut and it will be blocked.
I can't find the number but I think it was 1.5" and the shallowest one they made. And the 03 up pipe is fine, it doesn't have the big scoop in it.
cool man thanks .....i think im going to search for someone on the org who might live around me that can help me out doing it ....because i dont have a welder and i dont know how to weld plus im a little scared to take it on myself
Good looking truck!!
