Questions for the Mad Turbo Works Team - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-15-2013, 01:38 PM Thread Starter
Jweber6.0L's Avatar
I am about to start a pretty extensive build and want to use one of your turbos. While doing research I am seeing and reading contradictive reports on the production of your turbos. Recently I have read that you are doing away with the hybrid and going back to the stage 2. But on your website you are still advertising the hybrid. I was wondering if you could clear up if and when you are going to make the swap?
Also, on the FAQ portion of your website it says that the stage 1 uses a 11 blade and the hybrid uses a billet, but I thought I also read on here that your were moving the stage 1 to a billet as well?
Thanks for the time.
Jweber6.0L is offline
post #2 of 8 Old 10-15-2013, 02:41 PM
Hope you get an answer, I'm also interested in stage 2
bgraiders323 is offline
post #3 of 8 Old 10-15-2013, 03:10 PM
I think the new stage two will be named the MAD MAX. There is a thread on it.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #4 of 8 Old 10-15-2013, 03:12 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i wish i could still purchase the original stage 2
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #5 of 8 Old 10-15-2013, 03:33 PM
What was wrong with the original Stage 2???
post #6 of 8 Old 10-15-2013, 05:18 PM
colonel angus's Avatar
Quoted: 2 Post(s)
Cost to produce based on hard to acquire expensive parts.
The MadMax will beat the original Stage 2 hands down.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #7 of 8 Old 10-16-2013, 07:50 PM
madpowerstroke's Avatar
Thanks for your interest, currently I'm in heavy development of the turbos for the 6.0 powerstrokes. I don't want to let out too much about what I have planned, don't want to tip my hand and let any of my competitors know what I will be coming out with. The MTW line up will be a stage 1 for about same price, stage 2 for about 1400.00-1500.00, Madmax, stage 3, and stage 4. Thanks
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #8 of 8 Old 10-17-2013, 01:42 PM
MWilbur516's Avatar
All Stage 1 turbo's shave billet wheels, as do the Stage 3's and 4's. All future MTW turbo 's will also have billet wheels. So if you get a turbo from us , you will have a billet compressor wheel. We also have stock replacement billet wheels.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
