IT'S TIME TO START THE 6.7L FUEL PUMP! - Ford Powerstroke Diesel Forum
post #1 of 72 Old 10-14-2013, 05:51 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
OK i have all the parts necessary for the build but most important a brand new 6.7l pump. This pump is a monster of a pump rated at 120 psi from 1/2 feed and return. It will deliver 3 times the amount of fuel necessary for a 6.7l common rail so i'm very confident that it can handle our 6.0l even with the biggest injectors or so ill find out. I will keep everyone up to date on the build as it progresses and have all the part numbers for the build and cost. So fare the pump was 210.00 and the plug and bracket 75.00. The blades for the plug are huge and beefy as you will see in picks. i'm going to use heavy gauge wire and relay right off of the stock feed to energize relay almost just like airdog setup. here are the picks. Also im going to be installing the 6.7 CAC with a separate radiator and 6.4l electric fuel cooler pump to move coolant to the water to air CAC this should be real interesting to say the least!!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #2 of 72 Old 10-14-2013, 06:06 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Your insane Dale! Good luck!
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 72 Old 10-14-2013, 06:11 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Nice Dale!! How good is the water separator, filter micron, and air removal?
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 72 Old 10-14-2013, 06:27 PM
william_ace's Avatar
Quoted: 2 Post(s)
^^^ how does the water separator and what ill pooh said work??
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #5 of 72 Old 10-14-2013, 06:33 PM
peixinho's Avatar
Quoted: 207 Post(s)
ill pooh... thats funny
I am in on this one. Sounds really cool
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #6 of 72 Old 10-14-2013, 06:34 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
You know what's next Dale, don't you??
A complete 6.7 power-train swap...... I'm hoping to be able to do one on BACKYARDIGAN in a couple years....
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #7 of 72 Old 10-14-2013, 07:01 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
It is 10 micron just like others and best part is when you change the filter it releases a check ball that stops fuel flow. Great for trucks that have a sump in the bottom of tank. The wif circiut works the same way.I have had no 6.7l come in with water that has damaged the hpp at all and have not heard of any to date so that is a plus for the filtration canister. We have these trucks come in with 250 k miles on them with same factory pump so they have proven themselves to me already. I really think this is the answer to the crappy airdog 2 junk and is very affordible. ill be running it with a regulated return but it also will work with the stock return or a dead headed return with regulated return in front of heads.
A/C ASW A/W WINGS
post #8 of 72 Old 10-14-2013, 07:02 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Don't get me started id love to do that!!
A/C ASW A/W WINGS
post #9 of 72 Old 10-14-2013, 07:57 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Let's do it Dale. If you're going to spend money building a motor, might as well build one that has more power potential than any other powerstroke before....
Nate
post #10 of 72 Old 10-14-2013, 08:40 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Im in whos buying it to put in MY truck lol
A/C ASW A/W WINGS
