Before I bash Gearvendors I would like some of yalls opinions.
I just put the Gearvendors O/D on and went on a long haul. 70 mph on cruise 11.16 mpg loaded with a gross weight of 15,600 lbs. I thought not bad since I was getting 10.5 mpg empty. 90° temp outside, EGT 820-880°, Trans 172°, Boost 7-8 PSI and Water 198-202°. Empty was 12.75 MPG same 70 MPH cruise. Same outside temp, EGT 790-830°, Trans 169°, Boost 6-7 PSI and Water 196-198°. This was on the 165 hp canned tune. When I fill up it is pouring out pure diesel, no foam. That way I know it's full. All calculations are done by hand. What gives 2.25 MPG for $3250, come on there has to be a reason why I'm not getting the 14-15 MPG that I was promised. Any suggestions PLEASE! Last edited by oxman202; 07-12-2008 at 05:10 AM. Reason: wrong title |
I looked at a gear vendors and ran one in OBS f-350 4x4 with 7.3 for awhile. They are an investment that pays out over time, and they IMO allow you to really pull better in steep terrain which is what I bought mine for. I had the ZF5speed and I really needed the splits between 3-4 and 4-5 when hauling At the time I was not intersted in the mileage. it was 1998 HEHE diesel was cheap.
Now I'm getting 16.71 mpg. Way better the 12.75. All I needed to do was take that headache rack off.
Must have been a tall Headache rack.....Or just really heavy.
