a little confused....
so I bought the SCT SF3 from a sponsor last week. I got it in Yesterday and immediately plugged it in. It showed a 50hp, 65hp, Performance, and Street tunes. I went for the Performance first just to play around for a few minutes as I was in between cutting lawns. Anyway, after I got throught working and dropped the trailer, I rode around playing a little more then decided to drop it back to the 50hp tune. I cut the truck off and plugged in the tuner and all that comes up on the screen (after several attempts over the last 24 hours) is "filesystem initializing". I let it sit like that for about 10 minutes or so and nothing changed. What is the deal? Please help!!!!
not sure but here is a bump for you
Were you pulling a trailer when setting up sct. You may have issues with that. The sct is
taking a print of your stock file and your towing |
I had been towing, but had unhooked to upload the tune and then test. Played for about 15-20 minutes, then went and hooked back to the trailer, shut the truck off and started mowing for approximately an hour before ever starting the truck or pulling anything. The tuner had already run its course and was unplugged before testing or hauling....
no more thoughts, huh?
No, it doesn't say "finalizing". All that it will say is "Filesystem Initializing". It won't go past that. It is in small print at the top left of the screen. I'm going to call SCT in the morning...... Let's put our thinking caps on people!!!!
I would suggest contacting SCT. This doesn't sound like it's communicating with your PCM; it sounds like the device can't initialize due to a memory problem. Let us know how it goes.
Okay, I was on the phone with tech support at SCT for over 2 hours. This thing has everybody confused. Needless to say we tried update after update and to no avail. The programmer went back on Friday for a complete reprogram. I would prefer that they just replace it with a new one. I have this thing with electronics that don't work right. Guess we'll see......
