Sinister y pipe ? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-14-2013, 04:05 AM Thread Starter
turbotibbo's Avatar
Sinister y pipe ?
I just ordered the sinister y pipe . I am just wondering if I made a mistake ? Has any members tried it yet if so how do u like it ? It there any differance in spool up ? How was the install ? Thanks
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #2 of 8 Old 10-14-2013, 05:03 AM
madpowerstroke's Avatar
Funny you bring this up. I had trouble with my y pipe, the bellow blew out, it was a high performance bellow, the stainless mesh kind. I was trying to get ready for a dyno event so i ordered two y-pipes. One was the PPE stainless with high flow bellows the other was the Sinister y-pipe. The PPE came in first so that's the one I went with. The Sinister came in yesterday, I haven't even opened it yet. I talked to a couple of my customers and they said they liked it a lot and spool was faster then the stock pipe. After I do some track time on Thursday I plan on switching to the Sinister pipe to try it. I was planning to do a review on both pipes, the PPE pipe was a pain to line up, very stiff, so not much movement.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #3 of 8 Old 10-14-2013, 09:07 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
Sinister Y-Pipe
Looks like that guy had some install issues. They sure look nice...collector area looks much better than stock from what I can tell I the pic...I'd like it if tbe 2 pipes ran a little bit more parralell before they met at the collector, seem recent enough.
Do they make em for steed speeds? I didn't see anything on their site about it.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #4 of 8 Old 10-14-2013, 09:57 AM
Swackhamer's Avatar
I have one it lined up perfectly! It is a nice piece, And I weld stainless for a living!
04 F250 Leveled, Studded, Atlas40,SRL+, Blue spring, My 304 s/s Up Pipes, KC stg II, My Ported intake, 4" exhaust, My Head vents, Cat ELC and coolant filter, My Custom rear Bumper, My 304 degas tank, More home brew mods in the works
Swackhamer is offline
post #5 of 8 Old 10-14-2013, 02:19 PM
Installation was on the PPE pipes not the Sinister, haven't tried them yet.
post #6 of 8 Old 10-14-2013, 03:29 PM
i recently installed sinisters y pipe. it fit perfectly. very nice workmanship too.
lugnut is offline
post #7 of 8 Old 10-14-2013, 09:05 PM Thread Starter
turbotibbo's Avatar
Great news guys thanks , I am looking foward to gettin it installed . Sick of blowing stock y pipes . As for fittin on the steeds I don't think so . There made to go with sinisters headers if a guy wanted to upgrade later or whatever. I like the look o there headers too . Thanks for all the reviews , keep them coming .
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #8 of 8 Old 10-16-2013, 09:56 PM
Instead of starting new thread I will just post on here, hope the OP doesn't mind.
First on all I'm not a big fan of Sinister, and have ordered their limited edition powermax to get a look at it. It was not a ball bearing turbo that they claimed, and have also tried their other products in the past with disappointing results.
With that said I installed their y-pipe and it was a nice piece on equipment, welds very nice, the way the pipes go into collector also nice. The collector opening is smaller then the orginal size of opening which matches the turbo perfectly. I didn't modify the y-pipe at all just installed and tried it. Well here's my impression of the way it work, very nice, sounded better at idle and there was a noticeable quicker spool, and throttle response. I'm happy with it so far, I would buy one if I was looking to get better performance over the stock pipe for sure. The pipe is all stainless and has a slip pipe expansion joint, very nice piece, will keep updated on the long term but looks promising.
