smokes black in o.d. after getting on throttle hard - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-12-2013, 01:51 PM Thread Starter
simonswrecking's Avatar
I have an 05 6.0. 60,000 miles. sct tuner set on performance canned tune. ever since I bought this truck (3 months ago) after u do a wot romp. it will smoke black and kinda buck at 60 till o.d. kicks down. then it will clear up after a couple times doing this. should I be worried? just checked dtc's and have 1-8 injector low circuit and ficm code. help!!!
simonswrecking is offline
post #2 of 7 Old 10-12-2013, 02:29 PM
colonel angus's Avatar
Quoted: 2 Post(s)
You need some kind of gauges, scangauge II etc. to know your #'s FICM, ICP, BST EGT EBP without this info. it's going to be hard to help you.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 7 Old 10-12-2013, 03:33 PM Thread Starter
that's what I figured. I just wondered if maybe is was common. thanks
post #4 of 7 Old 10-12-2013, 04:09 PM
snafu!'s Avatar
What was the ficm code # that is most likely your problem.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #5 of 7 Old 12-05-2013, 03:38 PM Thread Starter
the codes are 0266,0273,0278,0611,p2614, and p2617. tested ficm yesterday has 47 volts key on, 30 while running. guessing its probly ficm? its under warranty so I guess i'll take her to the shop. thanks for the help guys!
post #6 of 7 Old 12-05-2013, 04:36 PM
45v is the ford service limit so anything less is considered failing.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #7 of 7 Old 12-05-2013, 09:45 PM
JesseKK's Avatar
Quoted: 84 Post(s)
Garage
My trukk smokes after hard acceleration. Vgt sticks wide open for about 10 seconds. I need to take it apart and clean it. :/
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
