Max potential power with stock injectors? - Ford Powerstroke Diesel Forum
post #1 of 25 Old 10-12-2013, 11:09 AM Thread Starter
Quoted: 10 Post(s)
My truck is at the dealer getting a new head put on. While it's apart, the mechanic is installing new gaskets and studs for me along with a new oil cooler and ipr egr delete. I just downloaded the looney wild tune. I plan on getting a mtw stage 1 turbo. I want to keep my stock injectors for now.
Also has anyone run water/meth with a similar setup to mine? And what power should I make?
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #2 of 25 Old 10-12-2013, 11:15 AM
madpowerstroke's Avatar
I have had customers run that set up and depending on health of their trucks and tunes, I have seen 475-490rwhp on stock injectors, and one of the stage 1. Water meth will add depending on mix about 30-50rwhp, so you could break 500 rwhp on stock injectors, water meth and a turbo. The customers were also running a FICM tune to get every drop of fuel, 80-120 tune.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #3 of 25 Old 10-12-2013, 11:28 AM Thread Starter
Quoted: 10 Post(s)
yeah I forgot to add I want to upgrade the FICM. I'm just not sure which one is best for my needs. Have a suggestion?
post #4 of 25 Old 10-12-2013, 11:37 AM
I'm not much into FICM tunes being stacked on performance tunes with bigger then stock injectors. I do think you do get added power for stock injectors, since you are trying to get the most fuel you can. I have seen IDP, and PHP FICM work very well. PHP is nice since you can get the programmer and try out 20-120 FICM tunes to see which works the best. I have 225/75 injectors and do run a 20 FICM tune with the performance tune, and tried the 40 but it was a little too much. FICM tuning with the larger injectors just gives you little more throttle response but very easy to over do and have a smokey mess.
post #5 of 25 Old 10-12-2013, 11:40 AM
Term3's Avatar
Quoted: 2 Post(s)
BPD is the ONLY one that makes a TOTALLY new FICM power supply to MILITARY specs. You can chose stock voltage or 58 volts which is surprisingly so much quieter and starts so much better. There are several places that re-solders the OEM FICM's power supply side of FICM but that's still the poor quality circuit board and parts. IMO there is no other choice if you want the best. I'm not saying that those other companies are not putting out top notch work but its still parts supplied by the lowest bidder.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 25 Old 10-12-2013, 11:40 AM
843Powerstroke's Avatar
Quoted: 6 Post(s)
*SOLD*1994 Twin Turbo Supra
843Powerstroke is offline
post #7 of 25 Old 10-12-2013, 04:01 PM
Chatham036's Avatar
Quoted: 150 Post(s)
Not sure if you are aware of this, but Bill can now custom tune your FICM to make the file work perfectly with your larger injectors.
To the OP, things are in the works for me to try this combination of modifications out in the next couple weeks. Personally i want to know what the absolute most i can pull out of stock injectors is. I will have dyno numbers to back any 'seat of the pants' feelings I can describe
If you would like to shoot me an email ( jay@phptune.com ) or call our office on Monday I will be happy to discuss why my plans are, research I have gathered, and any insight I can offer for questions you may have!!
Jay
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #8 of 25 Old 10-12-2013, 04:12 PM
snafu!'s Avatar
Jay
Interesting, more info please.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #9 of 25 Old 10-13-2013, 05:27 AM
Chatham036's Avatar
Quoted: 150 Post(s)
On the tuning or the build?
post #10 of 25 Old 10-13-2013, 06:15 AM
william_ace's Avatar
Quoted: 2 Post(s)
On the ficm tuning that works with bigger injectors. Please explain!
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
