think my boost is way too high - Ford Powerstroke Diesel Forum
Old 07-09-2008, 05:25 PM
ok well i have sct xcal3 w/custom tunes from dj's and the other stuff in my sig and right now im using there tow tune .......well i tow a texture rig for my company and i can be going up a little grade and if i give it gas it will down shift and my boost will hit 35 ...isnt that a little high? but even on the street towing nothing with nothing in the bed i can get about 30.....so what does everyone else boost ? i think mine is a little high
Old 07-09-2008, 05:36 PM
with an 03 turbo i beleive they will reach that
Matt
Old 07-09-2008, 05:39 PM
I have said it before but with my set up in my sig I can hit 33 psi like nothing in my truck. No head studs yet and no problems either. Keeping my fingers crossed.
Old 07-09-2008, 05:54 PM
i get scared when it hits that high
Old 07-09-2008, 06:45 PM
since i got my gauges in, my truck (Stock) hits 29lbs easy.....if your going up hill like that then i sounds right.
Old 07-09-2008, 06:52 PM
yep my 04 will hit 32 stock !
Old 07-09-2008, 06:59 PM
Slacker
Feedback Score: 4 reviews
You're fine, bud. Those 03 turbos could hit 35 pretty steady.
Old 07-09-2008, 07:05 PM
thanks for the info guys just thought it was a little high but if its normal then thats good ....
Old 07-09-2008, 07:31 PM
sprman
Guest
Posts: n/a
on my 05 i peg my 35 on my gauge all the time. not sure if i go any farther cause my gauge is maxed out at that point. You'll be ok
Old 07-09-2008, 08:01 PM
my 04 hit 55psi on stock turbo with xcal2, scary feeling..
