Harbor freight parts washer- - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-12-2013, 07:08 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
#1-I know this isnt in the right section so MOD's feel free to adjust as needed. (wasnt sure were to put it!)
#2 I know harbor freight is not snap on.
20 Gallon Parts Washer with Pump
Hey guys, was wondering if anybody has had any excperience with these. I would love a small washer for simple jobs. I dont need anything fancy and for $100 buck this sucker could be awesome!
My concern is with freezing. What do you guys use in the winter time? It sais to use a water based solvent, could I add some RV anti freeze with it?
Does it drain out of the pump when you turn it off?
Any of your thoughts on this would be great. Thanks
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 12 Old 10-12-2013, 07:19 AM
I love it!!!! Ive had one for a couple years now and it gets the job done.. I don't use a parts washer daily so I didn't see the need to fork out big bucks for a snap on.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #3 of 12 Old 10-12-2013, 07:21 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
What do you use for solvent ?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 12 Old 10-12-2013, 07:21 AM
As far as winter time.. I didn't do anything to the solvent- my garage doesn't get below freezing so never thought about it.
bpd
Warren comp trans
04cr450 is offline
post #5 of 12 Old 10-12-2013, 07:23 AM
I get the solvent at any auto store... I currently have crc parts washer cleaner. 5 gallon buckets
bpd
Warren comp trans
04cr450 is offline
post #6 of 12 Old 10-12-2013, 07:23 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
ahhhhh you lucky sucker. Mines below freezing at this very moment!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 12 Old 10-12-2013, 08:14 AM
Quoted: 28 Post(s)
They make other parts washers out there that have heaters in them. Hot solution = degrease faster...
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #8 of 12 Old 10-12-2013, 12:52 PM
XL trash...
Merc82's Avatar
Quoted: 291 Post(s)
I have one, it gets the job done.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #9 of 12 Old 10-12-2013, 02:02 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
They have to make a antifreeze parts washer soulution....I would think they would.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 12 Old 10-12-2013, 02:37 PM
somthin333's Avatar
I didn't think that most solvents freeze. Here is a link to the Crc solvent that was mentioned before. In the customer Q & A someone asked if it freezes and they said it doesn't.
Buy CRC Parts Washer Solvent 05067 at Advance Auto Parts
2003 6.0 F-250-ARP headstuds, Sinister egr delete and coolant filter, 4" turbo back exhaust, BPD oil cooler, Edge CTS monitor, IDP Tunes, Cooper STT tires
somthin333 is offline
