water meth pump location??? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-11-2013, 02:25 PM Thread Starter
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 56 Post(s)
Feedback Score: 7 reviews
I have the Aem kit. Where does everyone mount their pumps? Is it quiet enough for in cab?
Pictures would help too!
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
post #2 of 19 Old 10-11-2013, 02:28 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive wondered about doing the in cab install myself. Dont know how much fumes youd get from windsield washer fld.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 19 Old 10-11-2013, 02:30 PM
colonel angus's Avatar
Quoted: 2 Post(s)
I wouldn't want a source for x # of gallons of anything inside the cabin. There's a reason these are designed and engineered to be mounted under the hood.
d
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #4 of 19 Old 10-11-2013, 02:36 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
If its mounted correctly Im not sure having the weight in the cab would bother me.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 19 Old 10-11-2013, 02:50 PM
Quoted: 2 Post(s)
Whats weight got to do with anything? 7 gallons of water wouldn't do anything good.
d
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #6 of 19 Old 10-11-2013, 02:54 PM
Quoted: 2 Post(s)
The pumps aren't loud, just a vibration you can feel hear and it would be difficult to route the plastic hose thru the firewall, it would take 2 holes due to inflexibility.
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #7 of 19 Old 10-11-2013, 03:19 PM
snafu!'s Avatar
This is the start of my install, as long as the inlet to the pump is lower than outlet of the tank you will be fine.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #8 of 19 Old 10-11-2013, 05:28 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
I run the Snow Performance Stage 2. My pump is mounted under the pass side battery tray (upside down). I don't have pics of the pump mount location.
I relocated the vacuum pump resivour to the pass side frame rail to make room under hood for 7qt tank.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 19 Old 10-12-2013, 01:31 PM Thread Starter
Quoted: 56 Post(s)
mine has the 5 gallon tank, that i was going to mount behind the drivers seat. i thought about in my tool box but i didn't think that much line from the pump to intake would be able to keep pressure for the nozzle...? if it works, ill mount everything in the tool box.
post #10 of 19 Old 10-13-2013, 12:59 PM Thread Starter
Quoted: 56 Post(s)
any other opinions? can i mount the pump below the cab, or on the frame rail?
