Scared of my FICM tune - Ford Powerstroke Diesel Forum
post #1 of 31 Old 10-10-2013, 08:39 PM Thread Starter
BlizzardX23's Avatar
Soooooo...my FICM went bad...sent it to ficmrepair.com (awesome company!)
Ed told me the dangers of the Hercules tune..but...more HP?? I have to have it!! lol...
My truck is stock in the way of modifications...except, I took the exhaust off...right now, the exhaust stops after the downpipe....
The new FICM should be here in a few days...I told Ed (while I tried to convince myself) that I would be easy on the truck...but I have no way to monitor the EGTs...and well...I am worried if I just did something that I have no way of controlling...did I just screw myself?
Thanks everyone!
BlizzardX23 is offline
post #2 of 31 Old 10-10-2013, 08:42 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 902 Post(s)
Feedback Score: 6 reviews
You have no way of watching your EGTs? Do you not have gauges of some sort?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
post #3 of 31 Old 10-10-2013, 08:49 PM Thread Starter
I currently have no way of watching my EGTs...I have no gauges..the truck is pretty much stock
(I know I need gauges though)
post #4 of 31 Old 10-10-2013, 09:04 PM
peixinho's Avatar
Quoted: 196 Post(s)
well hercules is not the first mod I would do. I would start working on reliability mods first... but since you already pulled the trigger.
It is very unlikely that you will melt your motor right away with just a ficm tune. Many run ficm tune plus sct tune and still don't have any problems. It is very important just to take it easy. Any 0-80mph at that level should be fine. I would not do 10 0-80mph runs in a row without letting it cool off. Also I would not tow anything heavy unless on flat ground for very short distances. If you see it dumping smoke for a long period of time then you need to let off and let the motor cool off.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 31 Old 10-10-2013, 09:05 PM
peixinho's Avatar
Quoted: 196 Post(s)
short bursts of high temps usually do not cause any problems. It is the long sustained high temps that cause big problems
KC Turbos
peixinho is offline
post #6 of 31 Old 10-10-2013, 09:07 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
As I mentioned to Blizzard in another post, premature trans wear is another issue when running the motor at higher than stock hp/TQ without the trans being tuned to handle the extra power.
You will just need to take it easy and don't beat on it too much.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #7 of 31 Old 10-10-2013, 09:18 PM Thread Starter
Thanks everyone for the replies!
I can be honest with myself..and you guys...I know I'll romp on it once in a while...but knowing that I'm now playing with fire...I will be a lot easier on the truck! Lilpooh...your earlier reply is what made me post this lol...you solidified my fear...(I do thank you though!)
I do haul stuff...in the bed of my truck...maybe between 1,000 to 2,000 pounds max...when I get hired to work on a film set and they rent my truck and its equipment...other than that, it is empty everyday..
The last truck I had (03' GMC Yukon Denali)...it was a beast...lots of power...tuned, modded...etc...but that truck ran a transmission that would hold up to a high level of mods before needing to be changed out...is that not the case in these trucks?
I understand they are heavy duty..and built to work/haul...and aren't designed for 1/4 drags...but are they a fairly week transmission?
Anyways...I'm searching all over, reading tons of "gauge" threads...Im guessing it's gonna cost around $200 just to purchase, install, and run a pyro? (even if it's temporarily mounted rather than in a bezel)
post #8 of 31 Old 10-11-2013, 02:31 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Buy once cry once.. Get an edge CTS as that will give you around 20 things out of the box you can monitor. Then add your egt probe and fuel pressure sender and you're set
MrOneEyedBoh is online now
post #9 of 31 Old 10-11-2013, 02:35 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
If you tow or haul... Use the tow/haul and make sure you don't go into OD and your egt temps will be fine. Higher rpms equals more boost which lowers EGTs, but raises ECT and EOT. It's best to have gauges, but for now keep it out of OD while hauling up hills. Flat ground 1-2k lbs in the bed should probably be alright. It then again you have no clue how the oil cooler is doing... Get a monitor, ASAP! Even if its a app on your phone...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #10 of 31 Old 10-11-2013, 06:19 AM
portcity_gt's Avatar
Quoted: 1284 Post(s)
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
