SCT Tuner help?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-07-2008, 05:04 PM Thread Starter
SCT Tuner help??
ok guys i am new to this, ive searched but would like a direct answer to my questions. i have a 2004 f250 6.0, current mods are just 4" straight pipe turbo back, i want to get a tuner for it and have been hearing about the SCT. which one is best for my motor/ mods. the only other mod i plan on doing is cold air intake everything else is bone stock. ive heard of alot of problems with the 6.0s without a tuner and alot of problems with the tuner. my truck runs awesome right now and would hate to ruin it by puttin a tuner on it. it has 44,000 miles on it. what is the best tuner for me? ive heard of people blowin head gaskets and stuff like that and i dont want to have to deal with that stuff. any help is appreciated
2004 F250 POWERSTROKE DIESEL
AFE stage 2 cold air intake
6" STACKS
4" Lift
35" BFG M/T
yamahardr4e is offline
post #2 of 12 Old 07-07-2008, 05:08 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
SCT is the best for the 6.0 from any of the custom tuners
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 12 Old 07-07-2008, 05:09 PM
IUStroker6.0's Avatar
i was in the same situation a few years ago....
here's what i did: i wanted to eliminate the problem of the headgaskets blowing so i called 8-10 different dealerships around the area to see if they would do a head gasket replacement under warranty and while they were in there go ahead and replace my head bolts with arp headstuds. i finally found someone who would do it so it cost me 500 for the studs and 100 for a deductible.... good deal
after that i ordered my X3 from Dj's because i had heard so much about the looney tune. it is awesome, unlike any other tuner i have seen. i had previously ridden in 6 liters with bully dog, edge, and superchips and SCT shifts the best and overall tunes the best... not to mention the most power.
SCT is the way, and i'm sure others will agree. Innovative, Djs, and others will be able to hook u up. Good luck
2004 F-350 Reg Cab Long Bed 6.0l: Sold
2007 Dodge 2500 5.9l Cummins
White Quad Cab Short Bed 4x4
All stock
IUStroker6.0 is offline
post #4 of 12 Old 07-07-2008, 05:11 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
SCT for sure. Only problem I had was a clogged EGR cooler, and that can (and does) happen stock. And my tunes were a little "hotter" then average since I had studs planned.
If you're worried about the HG, try to locate a dealer that will replace the factory bolts with headstuds under warranty, if there is warranty left on your rig.
Otherwise, enjoy a SCT and just have the tuner "dial" back the tunes to your comfort level.
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
post #5 of 12 Old 07-07-2008, 05:13 PM Thread Starter
well id probly have to run the tunes it comes with not any custom ones because i cant afford the headstuds and stuff. so would the tunes it comes with mess up my motor?
6" STACKS
4" Lift
35" BFG M/T
post #6 of 12 Old 07-07-2008, 05:19 PM
no u would still want to order custom tunes so they can write it specifically to your truck but in your email or phone call explain to them that u dont want a super hot tune because your HG might not be able to take it. there are tons of tunes out there for u. and when u get the money some day have arp's put in (and try to get it done b4 your warranty is out)
All stock
post #7 of 12 Old 07-07-2008, 05:20 PM
and i see that your truck is a 2004 just like mine so u might want to consider it soon if u are thinking about doing it at all
All stock
post #8 of 12 Old 07-07-2008, 05:30 PM Thread Starter
just bought the truck about 3 months ago and came with no warranty now what SCT should i get i see there is different models? and who should i go to to get tunes put on it
6" STACKS
4" Lift
35" BFG M/T
post #9 of 12 Old 07-07-2008, 06:15 PM
goodriddance's Avatar
truck has a 5yr.100,000 mile warranty from Ford
goodriddance is offline
post #10 of 12 Old 07-07-2008, 07:10 PM
ok so how did you handle the warranty and get them to put in aftermarket headstuds. . . (bare with my ive never had a warranty before) do you tell them you want the studs changed and they just do it for a hundred dollar deductible, with the catch being finding a dealership that will put on aftermarket studs?
realtree250 is offline
