Just want to share what happens with trans and big RWHP - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 76 Old 10-09-2013, 05:20 PM Thread Starter
madpowerstroke's Avatar
I have been seeing weird stuff happening with the transmission and the high level of power I'm making. When I want to get on it hard say for 35-40 mph, and spin the tires something weird happens. The truck decides to shift in between gears like into neutral. I thought maybe the transmission's clutches where going but they are not.
So here is what I have learned and sharing to help others. I talked to Jesse and Andy Warren who built the transmission I have and they told me that 6.0 does the problem I'm having due to the ECM. They told me that when the truck spins the tires the ECM sees that the wheel speed is not matching the transmission speed and through the adaptive learning makes the trans just stop working and puts it in neutral. Andy told me that Matt from gearheads turns the adaptive learning off to stop this from happening. Jesse sees it in the pulling truck when the tires are spinning hard and transmission is shifting into other gears.
For built trannies it is also wise to put a tune in and drive it easy until the trans learns before hitting on it. Sometimes the tranny might pound the gears extremely hard and bust something if you don't let it learn the tune. Hope the info helps out, ever since this truck has stepped into the big power there has been some things that need adjusted for it.
MT KingRanch likes this.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #2 of 76 Old 10-09-2013, 05:54 PM
JGman141's Avatar
Well that helps me a lot because Im having the same issue with the trans not shifting if I get on it hard. I'll have to let my tuner know and see if it makes a difference with it off. Thanks for posting that Adrian
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 76 Old 10-09-2013, 06:44 PM
kdogg85's Avatar
So, there is a performance fail safe.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #4 of 76 Old 10-09-2013, 07:07 PM
Heavy_GD's Avatar
Quoted: 1324 Post(s)
Feedback Score: 3 reviews
Almost idiot proof... almost.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #5 of 76 Old 10-09-2013, 07:13 PM
It's really hard to tune the 5R to do what you want, when you want, especially on a 6.0. It got better on the 6.4 with the addition of the separate TCM. Only 3 or 4 tuners can do it. That is why you see 4R conversions becoming more popular, way easier to control when they shift, the 5R has a lot of different inputs that vary when they should shift, regardless, when you hit "neutral", you are destroying your clutches/trans.
2006 F-250 4x4 ecsb, Elite stage 2's, VGT-SSX.
Vizsla is offline
post #6 of 76 Old 10-09-2013, 07:21 PM
I had this issue on a certain tune and strategy. Same tune and settings (confirmed by the tune writer) on a different strategy and the issue was gone. I noticed in my trunk on my strategys that the newer TCM strategy is great for low power and town driving. Now the older TCM strategys aren't as nice around town but don't seem to have the issues putting the power down.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #7 of 76 Old 10-09-2013, 07:21 PM
jcpsuperduty's Avatar
I just bought a heavy hauler race series from NADP and they told me to take the tune from sct out before before putting it in performance saying I could blow the pump. Do I need to have a specific tune wrote for truck now or just have current tune revised without the trans tune? If so, should I get rid of the tune altogether and just run ficm tunes? Sorry for highjack just firgured it fell in line with subject..
2004PSD CC Long Bed 4x4, Usual stuff and some more stuff.
jcpsuperduty is offline
post #8 of 76 Old 10-09-2013, 07:45 PM
colonel angus's Avatar
Quoted: 2 Post(s)
This latest revelation proves without a shadow of a doubt that these trucks weren't engineered to do what we're attempting to do with them and the learning curve can be exhaustive and expensive. There will always be a weak link and Adrian is the best at finding them. LOL So now it confirms what Adrian as tried to tell us in the past with 600HP and 900+ tq.... you will need a tranny.
So it seems even with a built tranny 700+ hp and 1?00 tq will destroy a tranny.
I"ll be completely satisfied if we can just get the Stage 1 & Stage 2 on some trucks and on the Market satisfying the majority of what we need these trucks to do.
I wouldn't be surprised to see an AT or worse MT tire explode on the street since they aren't Z rated and designed to be ran at 100 + MPH.
My .02
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #9 of 76 Old 10-09-2013, 07:51 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I wonder how guys like Ellerton and Marroni (hope that's spelled right) are able to control their 5Rs. They don't seem to have a problem and don't advocate the 4R either. I'm sure there is a lot to tuning (as with just about everything on the 6.0 ).
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #10 of 76 Old 10-09-2013, 07:52 PM
snafu!'s Avatar
I have experienced this, the trans just kicks out of gear while spinning the tires. Definatly not a shift flare, it was on one of Matt's tunes also. Is there a setting that he can turn off or is the strategy that he's writing off of?
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
