finally - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-06-2013, 09:42 PM Thread Starter
finally
I finally have all of my parts to get started on my engine. Bought the truck in February, started saving money and buying parts. Bad lifter wiped out cam and oil pump. Just waiting on machine shop to finish block and heads. Stage 2 colt cams billet going in.
ID:	177897   Click image for larger version
jpott62 is offline
post #2 of 10 Old 10-06-2013, 09:52 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Nice! Looks like fun
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 10 Old 10-06-2013, 09:55 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
Did you clean up the valve pockets in the heads yourself?
Sent from a phone that makes calls too!
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #4 of 10 Old 10-07-2013, 06:30 AM Thread Starter
Yeah I cleaned up the heads, amazing how much crap was in there. A lot of built up soot from egr and sharp edges. All I did was smooth everything out.
jpott62 is offline
post #5 of 10 Old 10-07-2013, 07:07 AM
Powerhead357mag's Avatar
What are the expected gains from the cams?
03 CCSB F-250KR daily.
Sct Super panty dropper and Loony
4in axle dump
Blue Spring
03 SCLFB DRW F-350 pull truck
Completely stock!!!
Powerhead357mag is offline
post #6 of 10 Old 10-07-2013, 07:26 AM
Quoted: 398 Post(s)
Garage
They look good! Gives me something to think about when I do my studs.... Whenever that's gonna happen.
post #7 of 10 Old 10-07-2013, 07:40 AM Thread Starter
When I talked with geoff from colt cams about it he said his truck saw a drop in EGT and a noticeable gain in power. He says this is the biggest cam we can run before we run into valve clearance problems. When I started looking into the cost of this cam versus the OE replacement cam the price difference wasn't enough to make me buy the OE.
jpott62 is offline
post #8 of 10 Old 10-07-2013, 07:42 AM Thread Starter
I bought a grinding stone kit from production tool supply and an air grinder from MAC tools with and extended shank, made it easier to control to do the porting. If you want I can get the part numer for the grinding stones and you can order it from production tool. It is a 50 piece kit and I was surprised at how long the stones lasted. I think I went thru 5 stones on the whole job.
jpott62 is offline
post #9 of 10 Old 10-07-2013, 08:57 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
You can also use those carbide bits on a die grinder...they make em short, long, coarse, fine...and for the narrow long 6.0 intake ports you gotta be able to get way down in there to make big big gains. Exhaust side short turn radii has some gains to be made, as well as intake opening...just make sure there's no oil and grease left in the port when you start grinding...its a magnet for the metal dust/shavings and when you fire the motor up it'll blow all that metal down into the cylinder. I've seen it done.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #10 of 10 Old 10-07-2013, 02:49 PM
Quoted: 398 Post(s)
Garage
I've done some porting/pollishing in the past, so I've got the die grinder and burrs. I have a sandpaper roll-up set too. Pretty handy for getting the bumps smoothed out. The nice thing about direct injection is that you dont have to worry about making the ports too smooth
