Barder stg 2 w/155 stock nozzle review - Ford Powerstroke Diesel Forum
post #1 of 93 Old 10-04-2013, 08:15 AM Thread Starter
borsky4's Avatar
OK, so I had a pmax with a batmo prior to installing the turbo, under WOT I can still hit 1700 egt if I hold it long enough although it definatly takes longer. Biggest improvements are down low in the RPM range it spools WAY better at like 1800 rpm with NO surge. Makes about 3 more psi WOT in the higher rpm's and about 35-36psi with the tq locked in OD @ damn close to a 1:1 ratio to ebp. Part throttle seems to move more air t make more boost with less throttle with lower EGT's. Havent really had a chance put a lot of miles on yet but will travel 500 miles on sunday so I will report back. Also am running vivians looney wild for pmax, will be trying tonys tune next because it makes a little less boost and seems to be better on fuel with the old turbo. Also cleans up the looney completely, but the air temps were lower here so that helps too.
other mods are afe,banks IC,and gogo manifold,
borsky4 is offline
post #2 of 93 Old 10-04-2013, 08:40 AM
portcity_gt's Avatar
Quoted: 1268 Post(s)
It seems to me that you getting way to much fuel ot not enough air for some reason. I dont think that small of an injector should be that hard to overcome. ..even if the injector was maxed out the pmax should have cleaned it up. 1700 with 155/stock and a stage 2 seems crazy
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 93 Old 10-04-2013, 08:59 AM
peixinho's Avatar
Quoted: 193 Post(s)
1700 seems pretty high for 155/stock. I would venture to say that 1700 would be too high with 155/stock and a stock turbo.
Not saying anything is wrong with the turbo because you had similar issues with the pmax. I would venture to say something else is wrong. Maybe a bad/dirty sensor or a leak in the exhaust or intake side of the turbo.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #4 of 93 Old 10-04-2013, 09:02 AM Thread Starter
borsky4's Avatar
no smoke... I always thought the same but ive come to the conclusions that casserly injectors just flow like a mofo, then I installed them I had trouble maintaining FP with a brand new stock pump had to add a fass LP pump to keep up. When lots of guys say that there stock pump could keep up to there 175's I dunno. Another guy I talked to with the same injectors and a hybrid reported the same egt's. I also forgot to mention in my earlier post that it hauled some serious ***.
Also ICP maintains 3.9ish, new ebp sensor newer egt probe, tied to edge insight, new hpop and IPR. I not sure what sensor you suspect? Doubt theres a leak with 36 psi and a 1:1 boost to ebp ratio, also new y pipes
borsky4 is offline
post #5 of 93 Old 10-04-2013, 09:11 AM
Maybe they sent you the wrong injectors by mistake, and theyre way bigger than 155/stock.
post #6 of 93 Old 10-04-2013, 09:17 AM Thread Starter
borsky4's Avatar
I thought that too, so I called casserly and found out they were 155 stocks not the 155 50's that I was sold by an unnamed vendor (I bought them through another company not direct from full force) So unless they had a mix up but I kinda doubt it.
borsky4 is offline
post #7 of 93 Old 10-04-2013, 09:32 AM
peixinho's Avatar
Quoted: 193 Post(s)
My stock fuel pump and hpop handles my 175/75s just fine
I also saw around 1800 egts with a stage 1 turbo
now with a stage 3 turbo i only see 1500 egts
maybe you should send them out and get them flow tested 155cc's is 155cc... not sure it is possible for anyones 155s to flow more than others 155s unless they have bigger nozzles (but bigger nozzles don't flow more, just dump faster)
I guess the most important thing is that you are happy and the truck hauls some serious *** as long as you dont melt your motor
KC Turbos
peixinho is offline
post #8 of 93 Old 10-04-2013, 09:59 AM
1fastTRX's Avatar
I noticed with quick tricks tuning that my truck ran hot in the lower gears at WOT (1500+). Almost like the converter was too loose. In OD if I rolled into with converter locked it stayed much cooler (1300). That was stock injectors. Gearheads tuning feels like it plants the power better in lower gears which I think spools the turbo better
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #9 of 93 Old 10-04-2013, 10:14 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
You are not getting a true 1:1 because your ECM maxes out on ebp at 39 psi (g). That's why you think you are running 1:1 You have to hook up an analog gauge to get a true reading of ebp.
You have a leak somewhere. You have to. 1700 wot egts are WAY HIGH when I ran my 175/75's on the dyno with my stage 1 highest egts were 1647. Also you have open port 155's which will NOT flow as much as plugged port injectors and also use WAY more hpo than plug port injectors this your 3.8v-3.9v ICP at wot.
Tuscany is offline
post #10 of 93 Old 10-04-2013, 10:24 AM Thread Starter
borsky4's Avatar
Well I will add that it takes a long wot run (like 0-100mph way longer then a dyno pull)to hit 1700, also me ebp never hit 39 it's usually like 36-37 and boost in od was 35-36 at high Rpm in lower gears its like 36 and boost was 28. I'm going to make a vid of smoke and my insight and post it. I doubt I have a leak if there is no smoke. I'm going to try Tony's tune as I know it's cooler but it is not a full fuel tune.
borsky4 is offline
