Cfm big mouth intake elbow and banks cac - Ford Powerstroke Diesel Forum
post #1 of 33 Old 10-03-2013, 03:32 PM Thread Starter
Gapowerstroke's Avatar
Does anyone know if the Cfm big mouth intake elbow is a direct replacement for the banks high ram that comes as a kit with their intercooler. Wondering if it will fit their larger tubes.
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #2 of 33 Old 10-03-2013, 03:35 PM
Java's Avatar
Yes it will work, I replaced my high ram with a CFM big mouth intake before i ditched all of it for a no limit intake.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #3 of 33 Old 10-03-2013, 03:36 PM Thread Starter
Why the change?
post #4 of 33 Old 10-03-2013, 03:39 PM
Java's Avatar
It looks a lot cleaner and the factory size pipes spool better than the bigger banks tubes.
Java is offline
post #5 of 33 Old 10-03-2013, 03:53 PM Thread Starter
Oh ok, I was thinking bigger tubes plus freer flowing cac would make it easier for the turbo to spool because of less back pressure from a freer flowing air path. Shows what I know, lol.
post #6 of 33 Old 10-03-2013, 03:55 PM
Java's Avatar
Lol i thought the same thing but i think it looses too much velocity with the bigger tubes.
Java is offline
post #7 of 33 Old 10-03-2013, 03:55 PM Thread Starter
I'll be the first to admit that my knowledge of forced air induction is extremely limited.
post #8 of 33 Old 10-03-2013, 05:24 PM
strokin6L's Avatar
Quoted: 4 Post(s)
I also went from Banks high ram elbow kit to the large mouth CFM+ kit to the No Limit. Love the No Limit CAC pipe.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #9 of 33 Old 10-03-2013, 06:04 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
I second that.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #10 of 33 Old 10-04-2013, 02:42 AM
jetjock15's Avatar
Quoted: 113 Post(s)
My banks elbow and pipes work great. Due to debate on here about the bigger pipes I recorded parameters on test runs before and after. There was no change in boost or spool, I even seem to feel the spool was slightly faster but not measurable. No way spending more money to replace banks elbow and pipes is worth the dough. Take your wife to a weekend getaway instead, much bigger dividends
I'm also a facts based guy, so if you truely break it down to physics, the larger volume will be slower to compress but will be cooler air - so just about a wash in power I'm guessing. I argue the stock turbo has no issue building pressure in the larger banks IC and pipes, so I enjoy the advantage of cooler air. My banks IC kit did drop the EGTs 50-100 across the board.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
