How necessary is EGR delete with tune if deltas are OK? - Ford Powerstroke Diesel Forum
post #1 of 86 Old 10-03-2013, 06:51 AM Thread Starter
'06 crew cab long bed 6-speed. All stock. 70K miles. Runs perfect.
I am in the process of ordering a Livewire TS from vivian to tune and monitor the truck. Fresh oil change, just ordered the blue spring and some rev-x.
My plan: Install the livewire (no tune) and run it for a bit to make sure everything looks ok with EOT and ECT, and FCIM voltages. IF EVERYTHING LOOKS OK i was planning on loading a quiciktricks tune. (street or looney, doubt clutch can handle looney tune).
My question: Provided that the ECT EOT temps check out ok, would it still be necessary to do the EGR delete now, or wait until it needs an oil cooler replaced? I was thinking to just change out all the coolant, flush it with DI H20 a couple times, then replace coolant and add a coolant filter. Then just keep an eye on my deltas.
All opinions are appreciated.
Stlavsa is offline
post #2 of 86 Old 10-03-2013, 06:57 AM
portcity_gt's Avatar
Quoted: 1361 Post(s)
I would monitor it and go from there, but its never a bad idea to get the egr cooler out or upgraded with a bpd unit. Especially if you already have a tuner on the way to turn off a possible cel
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 86 Old 10-03-2013, 07:11 AM
I would go ahead and delete the egr cooler or install a BPD cooler. The ECT/EOT are monitored as to keep up with the health of your oil cooler. If you believe your oil cooler good then just do the delete, for me since I was in there I went ahead and put in a new oem oil cooler.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #4 of 86 Old 10-03-2013, 07:18 AM Thread Starter
Ok. I plan to do the EGR delete regardless (and oil cooler at same time). I am just trying to get a grasp on how much of a priority the delete is. (like does it need done IMMEDIATELY?).
I am under the impression that if the oil cooler is OK, then the EGR cooler should be OK because the failing oil cooler is the souce of the EGR cooler failure.
If I can get by for a few months with fresh coolant and a filter and then eventually do the delete, that would be great, if not, I'll do it asap.
Stlavsa is offline
post #5 of 86 Old 10-03-2013, 07:28 AM
[QUOTE=Stlavsa;6813505]I am under the impression that if the oil cooler is OK, then the EGR cooler should be OK because the failing oil cooler is the souce of the EGR cooler failure.
This is not always the case. Egr coolers will fail even though you have a good oil cooler. Egr cooler cool exhaust gas that is going to be recirculated into your intake again. Removing you egr cooler will make your motor more efficient.
Blue Spring Mod
SCT Livewire ts
post #6 of 86 Old 10-03-2013, 08:44 AM Thread Starter
And I guess theres no point in removing the EGR cooler to clean it, if I do that I might as well just do the delete? Or is it less work to clean it for the time being?? (I'm still trying to figure out how im gonna handle all this **** from an emissions inspection stand point).
We dont have emissions on diesels but I dont know if it needs the EGR in there for visual inspection.
Stlavsa is offline
post #7 of 86 Old 10-03-2013, 08:54 AM
poorboy1964's Avatar
Quoted: 2 Post(s)
you could weld up both ends of the egr cooler and put it back, then from a visual stand point it looks like it's there, but blocks off flow of exhaust gases.
Tom
2003 CCSB 4X4 6.0 Born on 5/03 Tuned by Vivian, 4" Turbo Back Exhaust, Edge CTS w/EGT, Coolant filter. ELC. fuel pressure gauge,
2002 SCLB 4X4 7.3 Stock
poorboy1964 is offline
post #8 of 86 Old 10-03-2013, 08:56 AM
If you don't have emissions on diesel then you can delete the egr cooler. Here in nc we only have safety inspections and the hood is never raised.
Never heard of cleaning an egr cooler, I wouldn't advise it.
Blue Spring Mod
SCT Livewire ts
post #9 of 86 Old 10-03-2013, 08:58 AM
Plus since you have an 06, you might want to think about replacing the up pipe also. On the 06 there is a scoop inside that deflects exhaust into the egr cooler. No cooler replace with straight pipe.
Blue Spring Mod
SCT Livewire ts
post #10 of 86 Old 10-03-2013, 08:59 AM Thread Starter
OK so if I weld up the EGR so it still looks like its there, is that essentially the same as a delete? Then the only thing left to do is make sure the tuner knows about it?
Stlavsa is offline
