Best aftermarket exhaust?? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-01-2013, 10:58 PM Thread Starter
Looking to replace my exhaust with a aftermarket one and i was just wondering who has a aftermarket exhaust what it is and do you like it?
Thanks
-RCR-
Redneck_Coal_Roller is offline
post #2 of 17 Old 10-02-2013, 12:32 AM
585Amarillo's Avatar
There all pretty good are you talking about a turbo back or a cat back?
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #3 of 17 Old 10-02-2013, 12:36 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i just went cheaper brand stainless steel turbo back no muffler no cat im not sure the brand is a big deal.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 17 Old 10-02-2013, 01:01 AM
I'v had 4'' turbo backs from companys like banks, flo pro, mbrp get anything thats cheap they all do the same thing just make sure its straight piped no muffler or cat unless you live in cali!
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #5 of 17 Old 10-02-2013, 01:04 AM Thread Starter
I'll probably go with a turbo back exhaust, I really like the MBRP turbo back cool dual exhaust. Thinking I might go with that one, but wanted to check and see what other 6L owners have had and have liked or would recommend.
-RCR-
post #6 of 17 Old 10-02-2013, 02:18 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 106 Post(s)
Feedback Score: 3 reviews
Anything that is T409 stainless steel will work just fine. If you live where salt/chemicals are used in the winter use a T304 system.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is online now
post #7 of 17 Old 10-02-2013, 03:26 AM
lowrider284's Avatar
-RCR-
I have the MBRP cool duals on my truck. Expensive system in the T409 like mine but the system is made well. Sounds great and looks good too....still curious what it would sound like without a muffler.
lowrider284 is offline
post #8 of 17 Old 10-02-2013, 05:31 AM
sprksonu's Avatar
Personally I like diamond eye exhaust the price was great and the fit was too!
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #9 of 17 Old 10-02-2013, 05:37 AM
mach65's Avatar
Quoted: 135 Post(s)
Just delete your muffler and cat first. I had mine cut out and a piece of straight pipe welded in for 60 bucks including welding the hangers to the replacement straight pipe. Sounds awesome, breaths well when running and I can't imagine that you get that much more performance from an expensive aftermarket system that is a half inch or more in diameter. Just a thought and a cheap easy way to go.
Sent from AutoGuide.com App
2005 Lariat CCSB
Stock Motor
115,500 miles
edge insight cts
coolant pressure gauge in cab
high idle mod
muffler delete
cat delete
IPR coolant filter
EGR welded shut
mach65 is offline
post #10 of 17 Old 10-02-2013, 05:49 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I second the diamond eye system. It was harder tking the ole factory set up off the truck thatn it was to install the new. Sounds awesome and will probaly last for years.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
