Sct programer with no head studs?? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-01-2013, 11:54 AM Thread Starter
Dakota_james11's Avatar
I was looking into buying an sct programmer or a banks system... DO NOT HAVE HEAD STUDS. But I heard of lots of 6.0 guys running this on exstream with no studs and never having a problem... Do you recomend this? As long as I'm not towing a 20000 lb trailer will it be fine? Looking for input! I don't have the money for headstuds at te moment but I would feel much safer with them... WANT YOUR INPUT PLEASE!!
Dakota_james11 is offline
post #2 of 18 Old 10-01-2013, 12:17 PM
Quoted: 8 Post(s)
Get a monitor if you dont already have one. This will allow you to make sure your truck is healthy before tuning. When you order a tune, the tuner will ask if you are studded or not and write the tune accordingly. One thing to keep in mind when tuning a stock truck......if there is ANYTHING wrong mechanically it will show itself when the truck is tuned!
2005 F250 FX4 6.0 PowerStroke, Dashboss, Swamps 58V FICM, PHP Atlas 40 tune, Tony Wildman Extreme Tune, IPR Coolant filter, ELC Coolant, EGR....nevermind, updated stc, more to come!
Babyboy70363 is offline
post #3 of 18 Old 10-01-2013, 12:21 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Stay away from Banks. Far away.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #4 of 18 Old 10-01-2013, 12:23 PM
gotta_gofast's Avatar
Quoted: 61 Post(s)
While there are "head bolt safe" tunes, keep in mind a stock truck can experience head gasket or EGR failures. I personally would only tune the truck if you either have the cash to fix it or have another vehicle to drive in the event of a problem. I had studs and still blew the even side gasket by cyl 2. Part of the problem was that the cylinder heads were out of spec.
Regardless if you do/do not program your truck you really should invest in a monitor and/or gauges. If you're tuned I also highly recommend fuel pressure and pyrometer.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #5 of 18 Old 10-01-2013, 12:25 PM
XL trash...
Merc82's Avatar
Quoted: 306 Post(s)
I'm running an SCT X3 with multiple tunes and FICM tuning and still on stock head bolts. There are various tuners out there that will all work with you, you just have to specify if you want a tow, extreme or street tune etc. Just make sure when you have a tune written to specify you are non studded.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #6 of 18 Old 10-01-2013, 12:32 PM
wytetrash's Avatar
I am running a tune from innovative diesel with a sct tuner, with stock head bolts at the moment, and I'm experiencing no problems..just remember, don't go super hardcore with it, just get a good street tune and you should be fine. And with the EGR stuff, in my opinion if you don't have to do emissions then get rid of that junk. Just my .02 brother.
2004 F250 King Ranch 6.0 Powerstroke-S&B Intake, Banks High Ram and Techni-Cooler Intercooler, SCT Innovative Street Tune, MBRP 4 inch Turbo Back to 7in tip, Sinister Coolant Filter, Blue Spring Upgrade, River City Diesel EGR Delete, Zoodad Mod, 35x12.50r20 Federal M/T, 4inch lift
wytetrash is offline
post #7 of 18 Old 10-01-2013, 01:35 PM Thread Starter
THANKYOU guys for your input, some sct programers come with pre tunes already loaded in them, for a banks system, the one I am looking at comes with a palm and already tells you most temps and egt readings and what not, would this be fine to run for gauges or would I also have to add?
post #8 of 18 Old 10-01-2013, 02:11 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I woudnlt run pre-programmed tunes wit or without studs! Get an SCT WITH custom tunes and don't drive it like you stole it every single day... You should be fine, took mine almost three years and I drove the crap outa the truck the whole time. Egr cooler went causing the head gaskets to go... Monitoring closer could have prevented my head gasket failure.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #9 of 18 Old 10-01-2013, 02:26 PM
Sct and custom tunes is the only way to go
Sent from AutoGuide.com App
2006 f250
on 37s
few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #10 of 18 Old 10-01-2013, 04:06 PM Thread Starter
I've always leaned more tword sct anyways, I'm looking at the livewire... Is this any good or is anyone running it?
