MTW is going Powermax ? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-01-2013, 02:57 AM Thread Starter
madpowerstroke's Avatar
Hello, everyone as usual I like to help out when I can. I have been working on mods for the Powermax. So if someone has a Powermax and wants more out of it I will be able to convert it into one of the MTW stages. I will keep everyone updated on the pricing and when I will be ready to do so. Here is a example, you have a Powermax with 190/100 and not cleaning it up. Send it to me and I will convert to a the new Madmax, stage 3 or stage 4. You would save yourself as much as 1000.00 dollars off the pricing of the MTW turbo you chose.
The conversion will cover me going through the turbo and replacing any worn parts, new compressor wheel and turbine wheel.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #2 of 4 Old 10-01-2013, 03:14 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Your a busy man Adrian!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 4 Old 10-01-2013, 04:42 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
Did you get your new wheels in that you were waiting on?
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #4 of 4 Old 10-01-2013, 02:31 PM
licenced2burn's Avatar
How do you make it a stage 3-4 I thought they used a gt40 chra?
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
