Stock pushrods - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-30-2013, 04:57 PM Thread Starter
07DIESEL6L's Avatar
Stock pushrods
What kind of HP will the stock pushrods handle? Do the stock pushrods wear that much that it is necessary to install them in the exact same location as they previously were?
07DIESEL6L
Sent from AutoGuide.com App
07DIESEL6L
Bulletproofed
RCD EGR Delete
Sinister Diesel Coolant Filtration Kit
Warren Diesel 175/Stock injectors
ARP Studs
H&S Cold Air Intake
Mishimoto Intercooler Piping Kit
5" MBRP Turbo back with 8" Tip
Stock Turbo with billet wheel
Innovative 58v Tuned FICM
Tuning by IDP
07DIESEL6L is offline
post #2 of 12 Old 10-01-2013, 04:04 AM
Gearhead2012's Avatar
Quoted: 3 Post(s)
I've seen stock pushrods bend and wear out on stock power level engines. The amount of preload in the hydraulic lifter plays a huge role. If you're not familiar with how a hydraulic lifter works, as opposed to a solid/mechanical lifter look it up on Google. Basically the stock pushrods are too long from the factory, they've address this, now if you go to buy a new pushrod from ford you get a pushrod that is .050" shorter, same length as 6.4's. Aftermarket pushrods aren't a bad idea, as long as theyre the same length as the new pushrods from ford. The rocker arm geometry, and general valve train quality is pretty poor on these motors...stamped steel rocker arms provide less accurate rocker ratios. Stock lifter preload on 6.0's is normally around .100-.120"...it should be around .020-.040" preload, the shorter pushrods help, but there is a huge variance in rocket arms. We took 2 brand new rocker arms and measured lifter preload on the same pushrod and bridge location. One rocker provided lifter preload of right around .140", the next had about .060"...so a variance of about .080" between rocker arms. Thats also why some people on stock engines have piston to valve clearance issues, even worse if theyve been milled. They should have come with solid lifters and adjustable rocker arms from the factory.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #3 of 12 Old 10-01-2013, 01:39 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I just got all new ones and they are noticeably shorter. They all have same part number so not sure the location matters. The new ones have copper finish on one end and that it supposed to be the top (that end up).
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #4 of 12 Old 10-01-2013, 01:55 PM
Quoted: 3 Post(s)
If you buy new ones location doesn't really matter at all, if you re use your old ones, one of the main reasons to keep them in the same locations they came out of is because of the variance in rocker arms and in pushrod length. Even the factory pushrods will vary .010-015" in length from one another...if it ran well before, you don't want to put a pushrod back in the wrong spot, potentially tipping things over the edge as far as piston to valve clearance, or lifter preload. It probably wouldn't hurt 90% of the people out there if you mixed em up, but i wouldn't want to be a part of the other 10% lol. Best bet is like rob did and replace em all with the shorter ones...I think you said they were like 60 bucks or so?
Under construction
Machining the 6.0:
post #5 of 12 Old 10-01-2013, 02:09 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I got my pushrods from Tousley and they were 3.80 each.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 12 Old 10-01-2013, 06:12 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
So if you went and got aftermarket push rods are they shorter to? If so what aftermarket push rods would you recommend that are chrome molly.
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #7 of 12 Old 10-01-2013, 06:17 PM Thread Starter
07DIESEL6L's Avatar
Thanks for the info guys, I'm def replacing them now just not sure if I should stick with stock replacements or go aftermarket.
I had been looking at RCD's pushrods set for $249 just not sure if it's worth the extra cost over OEM. With the upgrades I'm doing I know I won't push close to 600 HP so just wondering if the aftermarket ones are really necessary.
07DIESEL6L
Bulletproofed
RCD EGR Delete
ARP Studs
H&S Cold Air Intake
Tuning by IDP
post #8 of 12 Old 10-02-2013, 02:52 AM
jetjock15's Avatar
Quoted: 113 Post(s)
I have no idea if aftermarkets are shorter like the new oems? With this unknown I would definitely go with new OEM, I too paid $3.80 per from the one formerly known as "Tousley"
post #9 of 12 Old 10-02-2013, 03:22 AM
Quoted: 3 Post(s)
Hey man, I don't know what aftermarket pushrods are the 'right' length. I think Adrian said he bought some RCD, he said they were .010" longer than stock 6.0 which would be worse lol. I don't know if they offer pushrods for a 6.4 that might be shorter. If I had upgraded valve springs i would definitely go with chrome Molly pushrods. Each pushrod opens 2 valves, so if you go from factory spring seat pressure of about 80-90 psi, to aftermarket springs...I think the ones I installed for Nate had about 125-130 lbs of spring seat pressure... so an additional 30-40 psi per spring means 60-80psi total additional increase in spring pressure to overcome to open the valves. If I was to run aftermarket springs or planned on spinning around 4-4500 rpm a lot, I'd go for aftermarket pushrods as long as they were the right length.
The other option is the 2500 dollar harland sharp rockers, they're adjustable so pushrod length is less critical, as you would set lifter preload just like you would a small block Chevy...or eliminate the other huge variable and go with solid lifters at the same time, in which case you would also pick up a couple extra degrees of duration, maybe a hair more lift, as you'd eliminate the sponge between your pushrod and cam.
Under construction
Machining the 6.0:
post #10 of 12 Old 10-02-2013, 04:04 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Very interesting! I think I will get one pushrod tomorrow and order 1 chrome molly and measure them just to see.
A/C ASW A/W WINGS
