Broken oil rail bolt - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Friz186
  • 1 Post By sinner6.0L
post #1 of 8 Old 09-28-2013, 02:06 AM Thread Starter
585Amarillo's Avatar
While finishing up my d-plugs, and stand pipes, and stc fitting. I broke 1 oil rail bolt with the torx head on it and two valve cover bolts any one have this experience before and any idea how to remove?
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 8 Old 09-28-2013, 04:09 AM
jetjock15's Avatar
Quoted: 113 Post(s)
That sucks, the torque on those is not supposed to be much. You got to drill inside the bolt and by the special bit that screws in reverse thread into the hole and walks your bolt out. Pain in the butt
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 8 Old 09-28-2013, 07:59 AM
Take your oil rail off and there should be enough of the bolt sticking out to grab with pliers or vise grips, same with the valve cover bolts. I would avoid drilling at all cost. If it broke off flush and you can't grab it try using a pick to spin it out. Without any pressure on them they should be loose enough to get out without having to use a easy out. Keeping the shavings out of the engine while drilling specially for the oil rail is damn near impossible.
Jeremy@TDA likes this.
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #4 of 8 Old 09-28-2013, 11:45 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Lol, if you didn't try these steps BEFORE you posted your helpless lol. You always want to try to back it out on its own before you drill. If you have to drill, rags a vacum and grease(apply around area shavings will stick to it) will help
post #5 of 8 Old 09-28-2013, 04:56 PM
Gearhead2012's Avatar
Quoted: 3 Post(s)
As far as drilling goes, mask off the surrounding area, even cover the bolt with duct tape, totally seal off everything around it. You can use grease as rob mentioned, others use magnets, and vacuum cleaner, but obviously magnet doesnt help with aluminum. If it wont spin out easily, as others have mentioned, or if here is not enough bolt sticking out to grab with vice grips, you can take a very acute punch, very sharp punch and try to spin it out, ive gotten them out that way before. Also, if it wont come out by hand spinning it, theres a 50/50 chance that an easy out wont work either. If it doesnt youll have to drill it out entirely and replace with a helicoil or key lock insert. Drilling a steel bolt out of aluminum is always difficult because if the drill bit isnt pefectly centered in the bolt, youll wind up drilling into the aluminum. Once the spinning drill bit hits the aluminum, itll drift further off center, because the aluminum is easier to cut than the steel bolt. If it doesnt come out easily pm me and i can give you lots of ways to get the bolt out or drill and replace with helicoil or thread insert. I take out a handful of broken bolts every day, 6.0s break the exhaust manifold bolts off or strip em out all the time. Its rare a day at work goes by that i dont take out broken bolts, theres lots of little tricks you can try to get the bolt out. Anyway good luck.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #6 of 8 Old 09-30-2013, 02:38 PM Thread Starter
bolt came right out i used pliers thanks for all your help!
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #7 of 8 Old 12-19-2014, 02:30 PM
Where did you find a bolt to replace it. The dealer ships around me don't have them
mayfikyl is offline
post #8 of 8 Old 12-21-2014, 01:47 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
I use my MIG to do all broken fasteners. Build it up and grab it with an extractor. I also have drill guides for 6.0/6.4s and 6.8/5.4/4.6s exhaust manifolds. I only go for those as an emergency.
You ever use a time-sert?
I have the part number at work for the oil rail bolt, if you need it I'll get it.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
