Turbo wheel and other improvements - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-27-2013, 10:15 PM Thread Starter
SAILOR97's Avatar
OK guys I had a number of people tell me to change my stock turbo wheel since I am rebuilding my injectors thru Warren with 155/stock. I'm just sucking it up and putting some stuff on plastic..lol...I'm replacing the FICM from BPD 4 phase for 495.00 and just ordered a coolant filter system from diesel site...now I'm also looking at an EGT probe/fuel press/turbo saver...I need some help though with this turbo wheel..Ford changed it back in 2006 and found Garrett stamped on it with part # 1877832c91 ser# 732468...so on diesel site with my 05 F-350 dually 4x4 6.0 they have 2 wheels and was curious if anyone could tell me which one I should go with...was kind of thrown for a loop as it showed stock and Garrett figured since ford did it it would be a stock...2ndly I just finished pulling the driver side apart down to the injectors...these I believe they have listed are ww2 and figured since I'm in there I will change it...but all I'm trying to do is get better fuel economy and more power for towing...I don't want to do any competition or go crazy in that direction...thanks a ton guys for any help as always..heck you guys showed me Warren and there awesome folks...will see if I still fill that way after injectors are rebuilt and installed...lol
Edge CTS Insight w/turbo timer, EGT probe, Fuel pres., SCT X4, DC Power 185 amp alt., NUC Motorsports deluxe oil bypass, Rotella 5W-40 W/Rev-X, Sinister Coolant Filtration, ZEREX CAT ELC-1, Dual Exhaust Stacks.
SAILOR97 is offline
post #2 of 16 Old 09-27-2013, 10:41 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
Need to check out Mad Turbo Werks. they seem to be about the best on the market right now and are at the same level price as a WW or maybe a lil cheaper. Pm windrunner408 on here and he will answer you very quickly.... when i do my turbo and injectors in the spring this is what im going with.
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #3 of 16 Old 09-27-2013, 10:51 PM Thread Starter
SAILOR97's Avatar
OK thanks FDChief...someone had said that but had lost the thread and deleted the PM
SAILOR97 is offline
post #4 of 16 Old 09-27-2013, 11:00 PM
Smoke Eater
anytime bro... good luck!!!
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
fdchief is offline
post #5 of 16 Old 09-27-2013, 11:06 PM Thread Starter
SAILOR97's Avatar
Thank you sir...I just PM'd him and shall see.lol
SAILOR97 is offline
post #6 of 16 Old 09-28-2013, 08:03 AM
Joeshu1000's Avatar
Not to derail the thread but, I would like to do 155/stock with a ww2 or a wheel from mad turbowerks at some point. Once you get it all back together, I'd be curious to know how it runs and the power difference. Thanks..
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #7 of 16 Old 09-28-2013, 08:29 AM
I can tell you from experience that a dual plane MTW wheel with a FICM tune from Innovative Diesel Performance made throttle response improvements over just the FICM tune. I don't know what 155s would add to the soup, but the MTW wheel is a winner!
OP, I think you will be impressed with the BPD FICM power unit, esp when you hold it up to your OEM unit. It isn't a repaired OEM unit, it is completely redesigned/improved. I bought the 6 Phase and set it on 58V. It was a straight forward install and it was one of the FEW parts that I have used that looks to have actually added to MPG. Honestly, most parts that claim MPG gains don't in my rig.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 16 Old 09-28-2013, 08:52 AM
FYI in order to prolong your turbo life and save yourself some beaver pelts in the future take your turbo in to a reputable shop and have the shaft re-balanced with the new wheel. I know you can just change them but I'm telling you all the turbo's we rebuild with after market wheels need re-balanced. You would be surprised how far out they are on a balancing machine. Sure it will run for awhile but eventually sure as the sun rise it will let go eventually.
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #9 of 16 Old 09-28-2013, 02:24 PM Thread Starter
SAILOR97's Avatar
Joeshu, I will let ya know. I just ordered the BPD FICM I stayed with the 4 phase. And just came in to take a break as I have the driver side injectors out now..and down to the valve covers on the other. I also purchased a coolant filtration system from strictly diesel.
OK I will look into the rebalance thing...thanks for the heads up...but darn it that's gonna put the project back a lil...as I did not want to pull the turbo...lol
SAILOR97 is offline
post #10 of 16 Old 09-28-2013, 04:01 PM
legionxxii's Avatar
pulling the turbo really isnt that bad when installing it just make sure you take your time on the y pipe and downpipe to get it seated well so your not digging around looking for a leak
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
