valeo intercoolers... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-27-2013, 05:15 AM Thread Starter
livinlots26's Avatar
Ive been kinda hunting around for a "decent" priced intercooler to replace the stock plastic sided one and came across a valeo intercooler on ebay. Its all aluminum seems alright but has anyone run one of these? Will it offer an benefit over stock as far as lowering my egts a bit? Any info would be great thanks.
4 inch down pipe 5 inch stacks no cat, Powermax turbo, CFM large mouth intake elbow with larger pipe, S&B cold air intake, Edge juice with attitude CS with custom PHP tune. Atlas 80 ficm tune. Airdog2, TRP sump, 6.4 banjo bolts, Blue spring, Zoodad mod, Traction bars, counter sunk tool box molded around my stacks made by me, Coolant filter, ARP head studs, southbend duel friction clutch, complete EGR delete, DP mod, high idle mod, CCV relocation, 35 inch fierce attitude tires on 17" helo wheels
livinlots26 is offline
post #2 of 12 Old 09-27-2013, 05:39 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im in this same boat with you. Sadly the words "decent priced" and intercooler don't seem to mix. Ill be watchin to see what you come up with.
Have you checked out the banks system yet?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 12 Old 09-27-2013, 06:13 AM
portcity_gt's Avatar
Quoted: 1358 Post(s)
Bulletproof diesel sells a kit to convert your stock cac into an all aluminum piece.
If you can tig weld or know someone who can its a much cheaper option.
I built one for my truck using thier parts back before it was on the market, my egt's drooped 100
Do-It-Yourself aluminum tank intercooler upgrade from Bullet Proof Diesel
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 12 Old 09-27-2013, 06:34 AM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
Thats awesome... Those BPD guys are on the ball man.
GD
Heavy_GD is online now
post #5 of 12 Old 09-27-2013, 06:40 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
good deal thanks for the link.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #6 of 12 Old 09-28-2013, 06:41 AM Thread Starter
I actually would have expected that much of an egt drop just from converting. .. thats worth the 270 its selling for. But how bout the valeros... I wonder if id get mabey a bit more of a drop.
post #7 of 12 Old 09-28-2013, 06:50 AM Thread Starter
post #8 of 12 Old 09-28-2013, 06:54 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
I'm running one of the BPD intercoolers and while I didn't notice a drop in EGT's specifically, it seems like there is a touch more power... It could be in my head, but I think that the MTW Stage 1 just flows the air a bit easier through the BPD intercooler, which is giving me a bit more power. I haven't had the opportunity to tow with it yet, but that's the real test.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 12 Old 09-29-2013, 06:32 AM
william_ace's Avatar
Quoted: 2 Post(s)
I'd like to see this eBay IC in person. Would be a nice, cheaper option for us.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #10 of 12 Old 09-29-2013, 07:35 AM Thread Starter
I went to their webpage... it seems like a direct replacement size wise... I know the bd, spearco,afe and banks are a bit thicker so maybe aside from being built better than stock its probabaly not going to have any flow gains.
