BPD Remote Cooler, Oil Change Question? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-25-2013, 08:00 PM Thread Starter
5fifty's Avatar
I am running the BPD remote oil cooler kit using the stock oil filter.
My question is for the guys running this kit, how are you completly draining your oil? Or are you just draining what you can out of the pan and leaving the rest in the cooler?
I know on my last oil change which was the first one since my install, I did not get all of what I initially put in back out during draining.
Has anyone installed a drain valve to aid in this?
Any other options other than taking the lines apart each oil change?
Would a bypass filter help with this if I can't efficently get everything out each change?
I know my Bobcats hydraulic system is like this and I only can drain from the plug. The rest stays in the system.
Thanks in advance.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #2 of 9 Old 09-25-2013, 09:10 PM
Thanks in advance.
There's about a quart for hpop you can't get out anyways I wouldn't worry about it.
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #3 of 9 Old 09-25-2013, 09:26 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Just drain and replace all filters. You'll be good to good! Don't forget the new oil too
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 9 Old 09-27-2013, 03:18 AM
Quoted: 57 Post(s)
I added the BPD bypass filter system with 2 micron Amsoil filter to go with the BPD remote oil cooler. One of the reasons is that you can never get all of the oil out of the motor during an oil change. It also keeps the oil much cleaner than with just a full flow filter.
I don't think you want to fully purge the cooler and lines of oil as you would have a brief period of "dry start" unless you re-primed the system with new oil afterward. That's also why BPD recommends filling the new filter with oil before installing.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 9 Old 09-27-2013, 08:53 AM
Term3's Avatar
Well you could get real anal about purging all the old oil out of your system like a buddy of mine does. He has an electric oil pre and post lube pump that he also uses to change his oil with so he doesn't have to crawl under his truck. He just hooks up a hose from the suction side of his pump to a pail of new oil and runs the electric oil pump about a minute and then he pumps his sump empty again. LOL like I said, he's a "little" anal about these things. I have the same electric oil pump but I just use it for turbo cooling after I shut my motor off.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 9 Old 09-27-2013, 09:20 AM
portcity_gt's Avatar
Quoted: 1267 Post(s)
Its like taking a poop.....you cant get it all out but it will be fine until you poop again.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #7 of 9 Old 09-27-2013, 09:46 AM
Quoted: 57 Post(s)
So, dump what you can. Worry about the rest later.
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #8 of 9 Old 09-28-2013, 06:32 AM
Slacker
Evil Eye's Avatar
Quoted: 198 Post(s)
Feedback Score: 4 reviews
LMAO!!! Wow... That makes complete sense to my 12 year old sense of humor!
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 9 Old 09-28-2013, 06:48 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
That brought a tear to my eye. I couldnt of said it better.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
