How to read ebp using livewire ts - Ford Powerstroke Diesel Forum
post #1 of 52 Old 09-25-2013, 06:56 AM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
Well I am pretty upset that the livewire ts does not read ebp (exhaust back pressure)... it seems so simple for the livewire to do it, the truck is already set up for everything. At first the livewire could read ebp but the equation was wrong. Then with all the complaints they got... instead of fixing the equation they got rid of it all together, so if you update or have a new livewire ts it does not even have the ebp pid.
I am determined to figure out how to make it work and I have a couple of different ideas... but I have a few questions and I need a little help from some electronic gurus here on the org (electronics are not my specialty )
As far as I understand it the ebp sensor is a 5 volt sensor. It reads from 0-5 volts which is a linear equation to equal 0-54psi... So I should be able to tie into the lines, and plug it into the livewire TS, select the firewire cable, select or make the correct formula, and bam I get my ebp sensor back.
Here are my naive electronic questions:
  • Will tying into the ebp wires disrupt or mess with the computer signals
  • what equation should i choose?
  • what are the 3 wires going to the ebp sensor (?ground, signal, 5v power?)
  • is there an easier way than what I am doing
Here is some good info from the 6.0 bible
On a side note if I can get this to work then I should be able to do the same thing with the boost side of things so I can read it correctly past 30psi
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #2 of 52 Old 09-25-2013, 07:01 AM
portcity_gt's Avatar
Quoted: 1402 Post(s)
You will use the analog input on the top. And you'll have to set up your own equation using live link.
my maths aint good enough to tell you what it needs to be though.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 52 Old 09-25-2013, 07:04 AM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
Thanks. I installed the egts sensor and fuel pressure sensor and it was pretty easy. Just did not know if I could use the same principles
Hopefully someone with better math Skillz than us can chime in
KC Turbos
peixinho is offline
post #4 of 52 Old 09-25-2013, 07:24 AM
Heavy_GD's Avatar
Quoted: 1580 Post(s)
Feedback Score: 3 reviews
Arent there SCT folk on this board?
GD
Heavy_GD is offline
post #5 of 52 Old 09-25-2013, 08:01 AM
Gearhead2012's Avatar
Quoted: 3 Post(s)
Subscribed. I'm curious about this. Maybe if enough people keep emailing SCT they can just fix it without all the monkeying around. I don't know if tapping into the existing wires would effect the readings to both the ecm and the livewire ts...which could be an issue if you are using a strategy that uses ebp. I would be worried that sending a signal to the ts might effect voltage drop going to the computer. You could get another sensor and pigtail and plumb in your own sensor...I'd probably go that route, then I guess it'd be the same thing as a fuel pressure sensor and getting the ts to read that properly. If you could check that against a known good way to measure ebp, a scan gauge or whatever. Some sensor manufacturers give you the formula.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #6 of 52 Old 09-25-2013, 08:35 AM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
Maybe we should all ban together and call sct and complain... it should not be that hard to fix the problem... It really makes me mad that they would delete the option instead of fixing it...
I am also curious if there are any sct folk here on the board
KC Turbos
peixinho is offline
post #7 of 52 Old 09-25-2013, 08:58 AM
Something else you can try, you can set up custom datalog layouts and flash them to the ts with livelink. You might just be able to turn ebp back on.
post #8 of 52 Old 09-25-2013, 09:34 AM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
My ebp is still on... I never updated.
But it does not read right
KC Turbos
peixinho is offline
post #9 of 52 Old 09-25-2013, 12:12 PM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
So i think the formula should be simple enough
0 volts = 0 psi
5 volts = 54psi
the equation is a simple linear graph so 54/5 = 10.8
so 10.8 x volts should equal psi
KC Turbos
peixinho is offline
post #10 of 52 Old 09-25-2013, 12:15 PM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
I would love to just tap into the existing wire on the ebp sensor that sends the signal to the pcm... then tie it into the livewire firewire plug, then I should be able to select that wire and set the formula to (10.8*v)
I just need to figure out if tying into the wire will disrupt the signal to the pcm
KC Turbos
peixinho is offline
