FICM problems? Upgrades? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-24-2013, 03:03 PM Thread Starter
BigRedPSD's Avatar
Quoted: 3 Post(s)
Hey everyone I'm here but a long time fan.
I got a "New" 04 6.0 and i think I'm having some problems with my FICM. When I start it up in the morning every things working great, no smoke, no long cranking, but after it starts and my SCT livewire is on my voltage is 43-46 (below 50 F outside) I'm thinking its starting to go bad. But it only does that in the morning until it warms up then goes to 47-48. What do you think? And if I'm going to replace it i want to upgrade. Whats the best upgrade for the money?
BigRedPSD is offline
post #2 of 18 Old 09-24-2013, 03:31 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site! The real bang for the buck would be the upgraded Bullet proof diesel ficm. Those are the best that your gonna find. If you drop the $ on one of those you could just about forget you even have a ficm . My suggestion would to just give them a call. Those guys are awesome to deal with and will tell you all about them,these guys have no problem working with you and answering question's!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 18 Old 09-24-2013, 03:39 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
The second route that you could go is to ficmrepair.com. That's what I did just cause I didn't have the cash for the BPD set up.
But I will say so far Im 100% happy. He threw the atlas 40 tune and I was shocked how much better the start up, the spool up of the turbo and the extra fuel mileage is just a nice bonus! (no joke I figure Im at about 1.5 mpg's better now.)
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 18 Old 09-24-2013, 03:49 PM
JustinOOO9's Avatar
Quoted: 460 Post(s)
Garage
before you buy a new ficm, check your battery and alt as well. 46 volts is still within spec. if the batteries are more then 4 yrs they should be replaced. i went with ficmrepair.com as well great service, time!
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #5 of 18 Old 09-24-2013, 07:55 PM Thread Starter
BigRedPSD's Avatar
Quoted: 3 Post(s)
Thanks for the info guys. I've heard a lot of good things about ficmrepair.com and that's the route I would most likely go with. The battery's I'm not sure how old they are just bought the truck a few months ago and the alt is charging at idle 13.66
Early 04
head studs, cat delete
egr delete, altas 40 ficm tune
sct Livewire, PHP 140 Extreme tune, afe intake
blue spring, 285-75-r17 on addict XD wheels
post #6 of 18 Old 09-24-2013, 07:58 PM
JustinOOO9's Avatar
Quoted: 460 Post(s)
Garage
alt sounds good, but I would hook up a volt meter and test batteries after they've been sitting for a night. i fried my ficm with week batteries lol but my new ficm is holding up great keep us posted on what you did the ficm removal job only takes about 30 minutes all you need is 10mm, and 8mm and i think like a small 1/4in wrench for one the bracket bolts on front of ficm
Justin,
post #7 of 18 Old 09-24-2013, 08:06 PM Thread Starter
BigRedPSD's Avatar
Quoted: 3 Post(s)
Yeah sounds simple enough. I'll call around tomorrow after I get off work and keep y'all posted.
Early 04
post #8 of 18 Old 09-24-2013, 08:14 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
If you are gonna call Ed @ ficmrepair have a pencil and paper with you cause that man is a boat load of info! And if he aint too busy...he will share! Don't freak out if you get the answering machine, he will call you back.
This is one of those rare win win situations in life. If you go with BPD, its gonna be a win. If you go with Ed....its gonna be a win!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 18 Old 09-25-2013, 02:38 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
Any voltage below 45V at ANY time indicates a failed power supply in your FICM. Just because it goes over that warm means nothing. It's toast.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #10 of 18 Old 09-25-2013, 03:24 AM
usnavyad's Avatar
Feedback Score: 3 reviews
I also went with ficm repair and it worked out great as and the atlas 40 is great as others said!
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
Tags
ficm , ficm powerstroke 6.0
