Turbo help. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-22-2013, 11:12 AM Thread Starter
pa05stroker's Avatar
Turbo help.
Pulled my Turbo to clean and install my billet wheel. Now putting it back together I can't remember which way the plate on the turbine side goes. This is the first time I've removed a Turbo. Can someone give me some help here. The one difference between the 2 sides I can find is the little dimple in the one side but the slots face differently if you change it. Turbo help.-1379877082779.jpgTurbo help.-1379877095836.jpg
05 f250 crew cab short bed, 4" zone off road lift, 35x12.50xr17, eagle alloy wheels, young's farm service egr delete, ipr high flow coolant filter, 5" mbrp exhaust no kitty, SRL tune from gearhead, updated stc fitting, stand pipes, dummy plugs, and blue spring upgrade. and a lot of dreams.
pa05stroker is offline
post #2 of 6 Old 09-22-2013, 11:31 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
It can only go one way really. You need to but the vanes in and then sit that ring on them.
dhanna6powerstroke is offline
post #3 of 6 Old 09-22-2013, 03:44 PM
madpowerstroke's Avatar
Put the turbine housing on bench, with the y pipe connection at a 45.degree coming towards you, the slot on turbine housing should be at about the 1:00 position. Next install the ring, will have to move the vanes to line up on slot on ring. Make sure the big slot on the ring for actuator arm is pointing straight down lined up with the first heat shroud attach point. It will be the first attach going counter clockwise from the y-pipe connection. Line up the actuating arm on the center section with the big slot and make sure it goes in, the center section may not be down all the way, but it's ok move the center housing keeping arm in place so the enter section alignment pin goes into the turbine housing. Center section should be sitting in the groove and flange should be touching all the way around. Hope that helps you out.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #4 of 6 Old 09-22-2013, 04:12 PM
casper4203's Avatar
Adrian,
Do you ever lube the ring and veins with anti-seize or anything?
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
post #5 of 6 Old 09-22-2013, 05:49 PM Thread Starter
I got it thanks for the help guys
post #6 of 6 Old 09-22-2013, 11:55 PM
Originally Posted by casper4203 View Post
Adrian,
I use a high temp anti-seize, for vanes and ring.
