What should i do next? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 09-22-2013, 06:13 AM Thread Starter
843Powerstroke's Avatar
Quoted: 6 Post(s)
Well I just sold my car so I'm wanting to take truck to the next level. Iv got studs ect...., sct, exhaust and intake. What do y'all think I should do next? Iv got an injector or two acting up now so I'm probably going to change all with some upgraded ones.
*SOLD*1994 Twin Turbo Supra
843Powerstroke is offline
post #2 of 20 Old 09-22-2013, 06:31 AM
Term3's Avatar
Write Up: Bullet-Proofing the 6.0L PSD.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 20 Old 09-22-2013, 06:54 AM Thread Starter
Quoted: 6 Post(s)
I'm talking about on the performance side of things. Like any suggestions on turbos? Iv herd mixed things about the powermax
post #4 of 20 Old 09-22-2013, 07:18 AM
william_ace's Avatar
Quoted: 2 Post(s)
What are your goals for the truck? Do you tow a lot? Are you looking to go fast?
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #5 of 20 Old 09-22-2013, 07:19 AM
USAFBowman's Avatar
Larger injectors built by warren diesel
Larger turbo either barder or mad turbo werks
Ported intake manifold
USAFBowman is offline
post #6 of 20 Old 09-22-2013, 07:22 AM Thread Starter
Quoted: 6 Post(s)
I never really tow anything of significant size. My goal is hp haha.
post #7 of 20 Old 09-22-2013, 07:22 AM Thread Starter
Quoted: 6 Post(s)
I'll check em out. Thanks man
post #8 of 20 Old 09-22-2013, 07:49 AM
peixinho's Avatar
Quoted: 178 Post(s)
A lot of things depend on how much money you have on how much horse power you want...
You could do 155 injectors with a stage 1 turbo. It would be a little bump over what you have now and not have to worry about any other big mods
You could also do 175s with a descent sized turbo and be right around 500hp give or take... but you will be getting really close to needing to do more upgrades. Your fuel system and transmission will be pushed to the limits. If you drive easy you will be fine. If you drag race, go to the track, or sled pull then the 175s will most likely kill your tranny and your fuel pressure will be low.
How big of a budget do you have?
Do you have any hp goals in mind?
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #9 of 20 Old 09-22-2013, 07:55 AM Thread Starter
Quoted: 6 Post(s)
Probably looking at a budget of around 3000. I would love to be closer to the 600hp range if that is doable on my budget.
post #10 of 20 Old 09-22-2013, 08:05 AM
peixinho's Avatar
Quoted: 178 Post(s)
How slightly built is your transmission?
Do you have an upgraded fuel system yet? Like reg return and aftermarket fuel pump/lift pump
600hp is more power than a lot of people think... lots of other things start going wrong with 600hp...
I am only at 530 and am worried every day that the tranny is gonna blow up, i really need to do a full system upgrade (still on stock), oh and traction becomes an issues.
600hp is most likely out of your price range of $3000 to have a good reliable setup.
Although you could get closer to 550hp with 175/75s and a descent sized turbo... that would be pretty close to your $3000 budget
KC Turbos
peixinho is offline
