injector o ring question ? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-21-2013, 09:05 AM Thread Starter
I had my injectors rebuilt and took them to 155/30 last summer. So far I have had to replace the o ring on top of number 8 injector once last fall and now I am replacing the rest today.
My question is, has anyone else had this problem after you had the injectors rebuilt and if there is a pattern, or just a fluke with me?
At the time I replaced the number 8 injector o ring I had an old set of injectors and pulled an o ring from one of them. I pulled that o ring and looked at it this time, it still looks good so I don't think its the o ring on the oil rail nipple just above the injector.
Does any one have a suggestion why it's eating o rings, it looks like it is wearing from the top down.
Dave
06 350 cc/sw/short bed, 155/30 warrens, arp studs, edge insight cts, modified intake no egr valve or a place to put it, egr delete, blue spring up date, sct with Vivians tunes, PHP ficm programer, AE scan tool, 3" down pipe 4"back magna flow muffler, ccv mod, pyro, 6.4 banjos, ipr coolant filter, stand pipes and dummy plugs, updated hpop fitting
Daves06 is offline
post #2 of 4 Old 09-21-2013, 11:57 AM
mechanix's Avatar
I had this happen. Its the orings on the nipples that feed oil to the injectors. I changed all the nipples and o-rings for around 400 or so. I can post up some pics if you like.
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
post #3 of 4 Old 09-21-2013, 12:12 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
It is quite possible the cup seals are leaking and spraying HP oil on the injector to cup seal. It might just be nicks or damage on the installation of the rail.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 4 Old 09-21-2013, 01:20 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
He is correct
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
