Need a custom tune asap truck wont run - Ford Powerstroke Diesel Forum
post #1 of 24 Old 09-20-2013, 03:01 PM Thread Starter
Like it says, I just got 155/stock injectors an. Blue fuel spring. It ran fine then went to drive and number 7 injector went out. Warren diesel says the truck thinks its over fueling it so it shut off that injector. They said it just needs a tune.
That's where I need help. Senior homecoming is tomorrow and this truck hasn't ran in 5 months. All it needs is a tune. If anybody could write a tune for me I will send you the info. I will pay for a fee if any. Email me at Reezy71x@gmail.com. Thanks
2008 F350 Lariat. Done: stud, RCD pushrods lifters valve spring porrted intake manifold, ported fuel rails, fass 150, sb intake, sinister egr delete, 5' exhaust, mini maxx with Gearhead tunes, RCD triple disc tc input shaft intermediate shaft reverse hub, red eagle clutches, transgo shift kit
Reezy71x is offline
post #2 of 24 Old 09-20-2013, 03:03 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
power hungry performance . com
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #3 of 24 Old 09-20-2013, 03:33 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Quick tricks automotive will prolly be the quickest
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #4 of 24 Old 09-20-2013, 04:02 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Ask Warren for one of his tunes... He supply's tune ONLY to those who have purchased injectors from him. Plus he doesn't charge anything!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 24 Old 09-20-2013, 06:46 PM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Why would the pcm think it's over fueling with stock nozzles?
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #6 of 24 Old 09-20-2013, 07:02 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
Not to scare you, but I lost cylinder #4 after a diesel shop rebuilt mine to "155/stock". He told me something similar. I ended up pulling the high pressure oil rail off and the top of the injector and coil came with the rail while a round shim, two bolts, and the rest of the injector stayed in the head!?!?! Yep, injector fell apart into pieces inside my motor. I really doubt a new tune will cure it. Do you have any codes related to cyl 7?
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #7 of 24 Old 09-20-2013, 07:37 PM
colonel angus's Avatar
Quoted: 2 Post(s)
I've never heard where the truck could turn off an injector, you need to look for codes and NOT drive it until you find out what really happened.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #8 of 24 Old 09-20-2013, 07:40 PM
ZMANN's Avatar
Quoted: 1357 Post(s)
agreed what kind logic would killing 1 injector for an over fuel be
that would Be like calling PHP for a Tune needed ASAP
We Miss you Ronnie
ZMANN is offline
post #9 of 24 Old 09-20-2013, 11:13 PM Thread Starter
The truck was tune was sct canned tune. Put It back on stock and it runs fine? Don't really know exactly what's goin on??
Reezy71x is offline
post #10 of 24 Old 09-20-2013, 11:23 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Wait Warren told you that the pcm shut down an injector due to over fueling? Well I know I wont be getting injectors from
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
