Blue spring HELP!!!! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-20-2013, 11:30 AM Thread Starter
I have people tell that I need to upgrade to blue springs. Can some one please tell me what are they talking about and why do I need to upgrade to them???
ElkSlayer72 is offline
post #2 of 12 Old 09-20-2013, 11:39 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
It's one spring in the fuel pressure regulator/upper filter housing. Currently w.o the blue spring you can have dangerously low fuel pressure at WOT. This spring will maintain a higher fuel pressure thus minimizing the potential for damaged injectors. It's one of those in case mods... Buy it from tousley parts.
MrOneEyedBoh is offline
post #3 of 12 Old 09-20-2013, 11:40 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 121 Post(s)
Feedback Score: 7 reviews
Fuel pressure regulator spring. Yes, do the blue spring update. sunrise ford has it.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #4 of 12 Old 09-20-2013, 01:45 PM Thread Starter
Thank You
Thank you for the information I was absolutely confused but now I understand
post #5 of 12 Old 09-20-2013, 01:54 PM
c dog's Avatar
I would recommend swapping springs. I went with the gillette spring instead of the blue spring
http://www.gillettdiesel.com/gdsfuelspring.aspx
c dog is offline
post #6 of 12 Old 09-20-2013, 01:56 PM Thread Starter
I just finished ordering a blue spring Thank You to every one
post #7 of 12 Old 09-20-2013, 02:01 PM
BBBRRRRRTTTTT
Quoted: 121 Post(s)
let us know if you need anymore help. the fpr cover can be a pain in the butt to get off..
post #8 of 12 Old 09-20-2013, 03:20 PM
VBPowerstroke's Avatar
mine came off pretty easy the other day when I put in my blue spring. I had more trouble with the intake tube.
Don't tread on me!
07 F250
8in super lift/ 37in NITTOs
Swamps 48V Ficm with Atlas 40 tune
EGR delete
ARP Studs/ Ford Gasket
Warren 190/75 injectors
Stage 3 Turbo
FASS 150 Fuel Pump
Regulated Return
SCT Custom Tunes
VBPowerstroke is offline
post #9 of 12 Old 09-20-2013, 03:35 PM
Term3's Avatar
Quoted: 2 Post(s)
It's been proven on a dyno that as fuel pressure gets above 60 psi the HP drops slightly. I gave my Gillette spring and its 100+ psi to a buddy and within a year he was getting fuel in his coolant. Was it the Gillette spring that did it I'm not 100% sure but it was the only mod he did on his babied truck.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #10 of 12 Old 09-21-2013, 02:33 AM
kcoyner's Avatar
Quoted: 74 Post(s)
"It's been proven on a dyno that as fuel pressure gets above 60 psi the HP drops slightly. I gave my Gillette spring and its 100+ psi to a buddy and within a year he was getting fuel in his coolant. Was it the Gillette spring that did it I'm not 100% sure but it was the only mod he did on his babied truck."
Was it a cracked head or injector cup?
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
