Working on the injectors, need some input - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-20-2013, 10:46 AM Thread Starter
07DIESEL6L's Avatar
I have finally found the time to tear the truck down and get the injectors replaced, had a #6 contribution failure. I am looking to just have the injectors rebuilt and upgraded but not sure if I should just go with 155cc and stock nozzle or go larger.
Once the truck is back together I will have the following installed:
SCT IDP Xtreme Race tune
5" Turbo Back MBRP
S&B CAI
ARP Head Studs
Sinister Diesel Coolant Filtration Kit
Sinister Diesel 20MM Head Gaskets
Ford "Blue Spring" Upgrade Kit
Ford Upgrated STC Fittings
Ford Upgraded Turbo Drain and Intake Pipes
Ford Upgraded Standpipe and Dummy plugs
NCHornet CCV Reroute Kit
Planning on adding the following in the immediate future:
Water/Meth Injection
BatmoWheel
Thanks
07DIESEL6L is offline
post #2 of 6 Old 09-20-2013, 10:59 AM
JGman141's Avatar
Do you tow a lot? I'd steer clear of the batmo and get a single plane wheel Instead
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 6 Old 09-20-2013, 11:01 AM Thread Starter
07DIESEL6L's Avatar
I don't tow every day just sparingly
Sent from AutoGuide.com App
07DIESEL6L
Bulletproofed
RCD EGR Delete
Warren Diesel 175/Stock injectors
ARP Studs
H&S Cold Air Intake
Mishimoto Intercooler Piping Kit
5" MBRP Turbo back with 8" Tip
Stock Turbo with billet wheel
Innovative 58v Tuned FICM
Tuning by IDP
post #4 of 6 Old 09-20-2013, 11:07 AM
peixinho's Avatar
Quoted: 176 Post(s)
Stock turbo with a billet wheel then I would stay with 155/stock or 155/30
If you were going with a bigger turbo I would recommend 175/stock. It is a big jump in power and is still a good injector to tow with. But a stock turbo is too small for that
SAY NO TO THE BATMOWHEEL
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 6 Old 09-21-2013, 09:11 AM
casper4203's Avatar
What would be an ideal turbo and injector set-up for towing? And will that still be fun when not towing?
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
post #6 of 6 Old 09-21-2013, 01:02 PM
mechanix's Avatar
I tow with 155/30 injectors with a Barder stage 2 and it tows great, nice and cool with a good tow tune.
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
