175cc injectors? Stock nozzle,30,50? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 09-19-2013, 01:09 PM Thread Starter
Im trying to see what the differences are between a 175cc injector with stock nozzle and aftermarket nozzles? Ill be pulling my injectors soon to be gone through and want to see what the advantages are between stock and aftermarket nozzzles? Going to still be on the stock turbo with possible a billet wheel and powermaxx or stg1 later down the road.
Thanks for your help.
Jimmy
JIMS SVT is offline
post #2 of 20 Old 09-19-2013, 01:53 PM
The larger nozzles is where the power is gonna come in. Quicker fuel delivery. You can get any size nozzle in a 175 and be ok as long as you have good tuning.
2006 f250
on 37s
few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #3 of 20 Old 09-19-2013, 01:55 PM
pjsf250's Avatar
what would be the best option for a stock truck that does do some towing of a 5th wheeel
stay stock or bump up
pjsf250 is offline
post #4 of 20 Old 09-19-2013, 01:58 PM
william_ace's Avatar
Quoted: 2 Post(s)
155/30's has proven to be a great injector for towing. Look up jetjock and his set up. He tows all the time with his truck and that is what he is using.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #5 of 20 Old 09-19-2013, 02:14 PM
For towing a budget friendly guys a 155/30 is a good option.
2006 f250
on 37s
post #6 of 20 Old 09-19-2013, 03:03 PM
peixinho's Avatar
Quoted: 231 Post(s)
155/30 is a great option for towing! Especially if you r planning on staying with the stage 1 or pmax.
175/stock also does pretty well. Once you put nozzles on 175s it can get hot and Smokey
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #7 of 20 Old 09-19-2013, 03:55 PM Thread Starter
I currently run Erics extreme street tune. After the studs and gaskets go in Ill switch to the extreme race tune. Guess Ill have to get him to modify the tune for the bigger injectors. Now to pick what ones to go with.
JIMS SVT is offline
post #8 of 20 Old 09-19-2013, 07:10 PM
In hindsight I should have went with 30's but my nozzles are different than most they were extrude honed to open them up back before people were offering nozzles for 6.0's when I had Jesse warren turn them into 175's his best estimate was to call them 50's. I have to be very carefully towing. They flow a lot of fuel I can see a significant fuel pressure drop with a full fuel tune even with my regulated return.
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
post #9 of 20 Old 09-19-2013, 08:38 PM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
I had 75% and now have 30% nozzles.. It is better towing but still not perfect.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #10 of 20 Old 09-20-2013, 02:59 AM
Gearhead2012's Avatar
Quoted: 3 Post(s)
Jesse warren steered me towards 175/30's and I couldn't be happier. Inhavemt tkwed much since then because my trans went out shortly after...not really the injectors fault...a litany of factors. Call Jesse up and see what he says, I trust his judgement pretty much 100%, this is his livelyhood...but more importantly as many as he's built he's probably seen every combo out there and knows what works well together.
From my injectors and reading other peoples results, and talking with Jesse...I'd say 30% nozzles are a good fit. You can still pull enough fuel out of the tune for towing without sacrificing atomization and all. If you towed either really often or a whole lot of weight is stick with 155's...but again just call Jesse and see what he says.
Also part of my decision to buy nozzles wasn't just performance related...I've seen a few core engines come in with injector nozzles that had evidently eroded or somehow melted the tip off...bad fuel or debris evidently can hurt the nozzles and cause issues, so I decided new nozzles were worth it for that and the performance aspect.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
