Shifting from 3rd to 5th livewire ts - Ford Powerstroke Diesel Forum
post #1 of 20 Old 09-18-2013, 10:05 PM Thread Starter
Brent Beeler's Avatar
I have a 2007 F250 with the 6.0 I just noticed the other day on my LiveWire TS according to the command gear displayed on the screen my truck shifts from third to fifth gear every time is that normal?
Sent from AutoGuide.com App
Brent Beeler is offline
post #2 of 20 Old 09-18-2013, 10:17 PM
USAFBowman's Avatar
Yes this is normal. This is why you hear of 3-5 shift flare.... Shifting pattern is 1 2 3 5 then lock the torque converter
USAFBowman is offline
post #3 of 20 Old 09-18-2013, 10:21 PM Thread Starter
Okay cool, I appreciate the fast reply makes me feel a little better. Thanks
post #4 of 20 Old 09-18-2013, 11:03 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Actually it depends on the tune. A tune with early lockup with shift as follows: 1 2 3 5 lock 6. And a normal tune (or stock) will shift like: 1 2 3 5 6 lock. Only in extreme cold weather conditions does a 5R110 use an alternate 4th gear but then doesn't use 5th... Here is a link to a great article on the 5R110
5R110 Info
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 20 Old 09-19-2013, 09:44 AM
USAFBowman's Avatar
I thought there was only 5 forward gears.... 1 2 3 (cold 4) 5.... I though the other "shifts" were just the torque converter locking.....
post #6 of 20 Old 09-19-2013, 10:46 AM
Jweber6.0L's Avatar
Did you read the article?? 6th Gear is overdrive. There are 2 shift sequences the torqueshift can go through, each one has a 5 gear sequence. So the transmission is technically a 5 speed, but with 6 gears. For the Livewire TS the computer just thinks 6th gear is 5th because it never shifted into 4th so there were only 4 gear changes. 1-2, 2-3, 3-5, 5-6.
Jweber6.0L is offline
post #7 of 20 Old 09-19-2013, 10:58 AM
USAFBowman's Avatar
Originally Posted by Jweber6.0L View Post
Did you read the article?? 6th Gear is overdrive. There are 2 shift sequences the torqueshift can go through, each one has a 5 gear sequence. So the transmission is technically a 5 speed, but with 6 gears. For the Livewire TS the computer just thinks 6th gear is 5th because it never shifted into 4th and there were only 4 gear changes. 1-2, 2-3, 3-5, 5-6.
So confusing
post #8 of 20 Old 09-19-2013, 11:01 AM
Jweber6.0L's Avatar
So confusing
Said the master F-16 crew chief
Just read the article.
post #9 of 20 Old 09-19-2013, 11:18 AM
USAFBowman's Avatar
haha hey now....
I never have really understood the inside of automatic transmissions. I will leave it to someone who knows what they are doing to work on the inside of one. There are just way to many ways to mess it up and way too many little pieces.
But believe me, I'm always up for trying to learn something new
post #10 of 20 Old 09-19-2013, 12:14 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
When it can't find 5th gear because its smoked it'll also use 4rth as a default. Ask how I know. Lol. Tried explaining this to my tuner who then told me I was nuts and there is no 4th gear. I won't open that can of worms again, but yes 12356 then lock of the torque converter is 'normal operation' in stock tuning.
A guy named mark k (kavlowski or something) over on powerstroke nation used to be a trans engineer for ford, helped design the 5r110. Very smart guy, and he has posted a lot about it over there.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
