Need help from some 175/75 injector guys - Ford Powerstroke Diesel Forum
post #1 of 56 Old 09-18-2013, 10:04 AM Thread Starter
peixinho's Avatar
Quoted: 214 Post(s)
So I recently added 75% nozzles to my 175 warren injectors. The truck ran great with 175/stock but now it seems to have a few issues with the 75% nozzles added.
Is it normal to have a slight chug at idle once the truck warms up? Not really a miss but more like a choppy idle? It does not feel like a miss at all and goes away once I give it any throttle
The motor does not like to be lugged... seems to run choppy
I am having egts issues even with new tunes. I tried running a tow tune and the results are all similar.
  • Idle = 350 (normal)
  • WOT 0-80 = 1400 (normal)
  • Cruising at 75mph = 950 (way higher than my normal)
  • 1/4 throttle from 0-60 = 1200 (way higher than normal)
Boost levels all seem normal
Back pressure is also normal
With the new tunes it is not overly smokey (like it was with the 175/stock tune)
vgt duty cycle is acting normal
Truck runs and drives great
No weird smoke on startup
No weird smoke while idleing
I know the atomization is not as good on 75% nozzles... but do those numbers sound way too high?
I hate asking tuners for tons of different revisions so I was hoping to figure out a baseline or if something else is wrong before I keep asking for revisions.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #2 of 56 Old 09-18-2013, 10:31 AM
Gearhead2012's Avatar
Quoted: 3 Post(s)
I don't have 75 nozzles, but maybe its relevant...my 175/30's don't do any of that lol. Cruising egt's at 65 were in the 800's...with ficm tune and Looney wild (which will not be going back on my truck when my trans is finished). My wot would get to like 1800 really quick, but that's stock turbo. Idles smooth as stock did though, a little more chatter from the injectors while its running, but no lugging or anything. I don't know if it helps at all, but for reference sake I figured I'd throw it out there about the 30% nozzles.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #3 of 56 Old 09-18-2013, 11:24 AM Thread Starter
peixinho's Avatar
Quoted: 214 Post(s)
Thanks... does does help a little. I have heard that larger nozzles do not run quite as smooth... Next time around I will not go with such large of nozzles...
800egt at 65 just seems a little high for me... I was more used to 675-750
Anyone else out there with larger nozzles have any similar issues?
KC Turbos
peixinho is offline
post #4 of 56 Old 09-18-2013, 12:13 PM
I have the same injectors with tsd super panty dropper tune and powermax... egts are same as yours except at 1/4 throttle or 60+ mph on flat ground is around 600 degrees... but a hard run I can make it get to 1581-1600 degrees quick but then it backs off.. no choppy idle etc etc engine idles and starts up like stock
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 56 Old 09-18-2013, 12:15 PM
colonel angus's Avatar
Quoted: 2 Post(s)
My 175's / 75's plugged spill ports drop a cyl. every so often.
I had Tony Wildman verify his does it too as well as one other.
I don't consider 75 nozzes as big nor 175 when comparing to stock so in my opinion they should function exactly the same as stock with a tune that removes fuel from the low end.
My truck Puffs at start up and smokes noticeable when idling out the CCV mod tube.
It will smoke out the pipe if watched in the mirror but can't be detected from behind a car length or two.
If i had it to do over i'd get 175's 30's with hopes it's a better and more tunable combination, but i'm waiting for the MaDmAx to fix all my problems.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #6 of 56 Old 09-18-2013, 12:18 PM Thread Starter
peixinho's Avatar
Quoted: 214 Post(s)
So what you are saying is
My normal numbers are just like yours but my abnormal numbers are different
Idle = 350 (normal)
KC Turbos
peixinho is offline
post #7 of 56 Old 09-18-2013, 12:19 PM Thread Starter
peixinho's Avatar
Quoted: 214 Post(s)
Denny
Thanks
If you don't mind me asking what r your egts?
KC Turbos
peixinho is offline
post #8 of 56 Old 09-18-2013, 12:21 PM
Quoted: 2 Post(s)
Originally Posted by peixinho View Post
Thanks
i don't have a monitor yet. use scangauge II
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #9 of 56 Old 09-18-2013, 12:23 PM
Idle = 350 (normal)
Exactly .. A 175/75 is a correctly sized injector. So the idling and operation of the injector should function just like factory etc etc..
bpd
Warren comp trans
04cr450 is offline
post #10 of 56 Old 09-18-2013, 12:24 PM
Since your egts are way out of whack im starting to think if you really have 175cc and not bigger? Have you ever had them flow tested by a 3rd party?
bpd
Warren comp trans
04cr450 is offline
