Which ficm aftermarket to buy? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 09-15-2013, 12:49 PM Thread Starter
If you were going to replace or repair your ficm, which aftermarket would you go with? Pros /cons? There are so many out there, not sure which to pick. I need to replace mine soon. Been getting 36 volts in the mornings.
Mstepka78 is offline
post #2 of 22 Old 09-15-2013, 01:13 PM
portcity_gt's Avatar
Quoted: 1205 Post(s)
Bulletproof diesel. /thread
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 22 Old 09-15-2013, 03:43 PM
hoogie's Avatar
i went threw the samething your going threw right now, i choose to go with bpd 6 phase....put it in at 58v and i've never looked back since...great product and starts great...fuel mph maybe just me but seems to of helped a bit also...just giving my two cents worth...hoogie
Mods that have been done
BPD 6phs 58v ficm
BPD Water Pump
IPR external oil cooler kit with high flow coolant filter
IPR GEN3 EGR Delete Kit
IPR Exhaust Up Pipe
4" turbo back exhaust
ARP studs
High Idle mod.
4" lift with 35" tires
CTS monitor edge juice with attitude programmer
Fab Four front bumper with Ramsey winch tucked in er
RoadRhino rear bumper with winch in er also
Fender flares with custom rock guard painted same color as the truck
hoogie is offline
post #4 of 22 Old 09-15-2013, 04:04 PM
USAFBowman's Avatar
In all reality you have three ways to go.. I will list them in order from best to "worst"
1. Bullet Proof Diesel Full FICM or FICM power supply
2. FICM Rebuild by Ed at FICMrepair.com
3. Purchase another one from Ford
With one you are buying quality of BPD which is the route I will be going. With two there have been quite a few people with good experiences with Ed, but for the same price you can just about get a new one from BPD. And with 3... well you could end up right where you are now withing as little as weeks, you are better going off with 1 or 2... but figured I would say this is an option, not the best option, but an option none the less.
HAHA I see what you did there
USAFBowman is offline
post #5 of 22 Old 09-15-2013, 04:10 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
^^^he hit it right on the mark!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 22 Old 09-15-2013, 05:11 PM Thread Starter
awesome thanks guys.
I am gearing towards the BPD 6 phase. Do I need to get the one with the logic board?
post #7 of 22 Old 09-15-2013, 05:13 PM
USAFBowman's Avatar
No it is not nesisary. Logic boards rarely fail. Yours should be fine plus if you are already FICM tuned with keeping your logic board the tune will "transfer"
I feel the only reason BPD started offering full FICMs (power and logic together) is for those who are scared/afraid to open their existing FICM to replace the power side. And I guess in a way to minimize down time. Or to allow someone to have a "spare" FICM assuming they just replaced theirs and the current one isn't bad. I actually may buy a full FICM and send it off to Ed to get tuned or purchase the FICM tuner out right. And that way I can keep my current one as a back up for myself and my buddies, and to possibly sell down the road
post #8 of 22 Old 09-15-2013, 07:40 PM
Quoted: 11 Post(s)
It's always been my understanding that a failing charging system is the root cause of failing FICMs. Last winter, I went with the Bulletproof 6-phase unit myself when mine got too bad to ignore any longer. I had previously had an issue with my alternator and batteries and ended up putting a new alternator and Diehard Platinums in but I think the damage had already started. When I put the Bulletproof FICM on I had already taken care of the other issues, but you would be wise to check out your components and replace any failing items as necessary. Otherwise your your new unit may end up joining your old one in the trash can.
David Frost
2005 F250 Harley 6.0 CCSB
Towerguy is offline
post #9 of 22 Old 09-15-2013, 08:43 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
I didn't even know BPD was offering full blown FICM assemblies.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #10 of 22 Old 09-15-2013, 09:26 PM
USAFBowman's Avatar
It's rather new... Only been out for a week or two
