Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
  #11 (permalink)
Old 06-10-2008, 05:21 PM
Jon
Tournaments Won: 1
Posts: n/a
Lower
Originally Posted by jfines@cox.net View Post
Now that you mention it, I do remember seeing a TSB about the full mark being wrong on the degauss bottle. But I don't remember if it was lower or higher then the full mark.
But he is actually using coolant.
  #12 (permalink)
Old 06-10-2008, 05:43 PM
TennesseeDuck TennesseeDuck is offline
I just want to keep an eye on this since my wifes truck has the exact same issue. I went to the dealer today and got a gallon of antifreeze so I can refill it in the morning.
  #13 (permalink)
Old 06-10-2008, 05:47 PM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
Listen to Jon. There is basically a little vertical radiator inside the egr cooler and the coolant leaks from there then the hot exhaust evaporates it and bam...white "smoke". Just to give you a better idea.
  #14 (permalink)
Old 06-10-2008, 05:48 PM
I use(d) hose water. OOPS! lol
  #15 (permalink)
Old 06-10-2008, 06:08 PM
topdwg topdwg is offline
What's weird though is I fill it up midway, then it'll only go down to the fill line. I've never seen it below this?
  #16 (permalink)
Old 06-10-2008, 06:35 PM
AvroAero AvroAero is offline
hose water is fine as long as it wasn't much. Should be 50-50 +/- 10%. Mind you it'd be better if it was distilled water. I read it should never go above 60% pure coolant.
  #17 (permalink)
Old 06-10-2008, 07:00 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
if this truck is an 04 , there is a good chance that the orange hose from the egr cooler to the oil cooler could be leaking causing a slight coolant loss, but it burns off before it drips , if this has been going on for a bit i would think the egr cooler would have taken a dump by now, if you get on top of the engine and look down in the valley of the engine , look and see if that connectore hose is orange or blue , if its orange thats the odl style and are bad to leak and cause the symptom you are having
  #18 (permalink)
Old 06-11-2008, 05:16 AM
I have blue hoses and I looked this morning and the level seems to be where I put it last night. I'll drive it around for a bit and see what happens...
  #19 (permalink)
Old 06-11-2008, 07:02 AM
POWERED SPARKLESS POWERED SPARKLESS is offline
CAN'T YOU SEE I'M BUSY
Quick question did you go to Sanders Ford? I've had nothing but bad luck there with my PSD.
  #20 (permalink)
Old 06-11-2008, 10:58 AM
Foamy Foamy is offline
Well yes there was a TSB for getting a new "sticker" for the degas bottle, which moved the min/max lines on the thing. The new max line is pretty much at the old min line. I got concerned when I noticed this on my truck and was told this from the dealership.
