Exhaust questions - Ford Powerstroke Diesel Forum
post #1 of 20 Old 09-12-2013, 09:30 PM Thread Starter
Kyleu890's Avatar
Exhaust questions
I have an 05 6.0 ccsb and would like to know if there are any cat delete pipes that bolt up to the factory down pipe? The reason I ask is my truck is under a 3rd party warranty and if/ when I take it in for warranty work I named to be able to put everything back to stock, including exhaust. I wanted to go a turbo back straight pipe but if I have to put the factory exhaust back on I do t want to have to deal with the down pipe. So I am just simply wondering if there is a cat delete pipe that bolts to factory down pipe so I can run a cat back exhaust that I can bolt on and off. Or if anybody knows of a turbo back exhaust that can be swapped quickly or any other ideas or suggestions would be appreciated as well.
Sent from AutoGuide.com App
04 ccsb f350 little red rip! Previous truck
05 ccsb f250 currently bone stock no plans to change it.
Kyleu890 is offline
post #2 of 20 Old 09-12-2013, 09:36 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Yeah there is. Just google cat delete pipe. Almost always this will be the stock size piping because its very rare to upgrade the exhaust and upgrade the cat to a larger diameter as well. When I upgraded my down pipe I gave away my cat delete pipe, sorry man.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 20 Old 09-12-2013, 09:37 PM
Quoted: 8 Post(s)
Here ya go...
https://www.google.com/search?q=6.0+...+pipe&tbm=shop
Those MBRP are exactly what your looking for!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #4 of 20 Old 09-13-2013, 06:11 AM
colonel angus's Avatar
Quoted: 2 Post(s)
an exhaust shouldn't void any warranty and it would be up to the repair shop to divulge that you had any changes to the approving warranty Company - most likely in another state and wouldn't send a rep. out to verify anyway.
what i'm trying to say is, you'd be fine replacing the exhaust but you may have to cut the exhaust if you go Turbo back... and it's easy to R&R if you only do a cat back system.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #5 of 20 Old 09-13-2013, 10:40 AM
Originally Posted by RollinEarly99 View Post
Here ya go...
I was told the MBRP delete pipes don't fit the stock system for some reason.
I went with this one instead.
03-07+ Ford 6.0L Powerstroke Diesel Cat Delete Pipe
schwartzworld is offline
post #6 of 20 Old 09-13-2013, 11:25 AM Thread Starter
Kyleu890's Avatar
Thanks for all the input!
Kyleu890 is offline
post #7 of 20 Old 09-13-2013, 11:26 AM Thread Starter
Kyleu890's Avatar
Did the pure diesel pipe fit the factory down pipe?
Kyleu890 is offline
post #8 of 20 Old 09-13-2013, 12:44 PM
Quoted: 8 Post(s)
I got my MBRP delete pipe from a member on the org and it fit perfectly!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 20 Old 09-13-2013, 12:47 PM
DunesRunner08's Avatar
Turbo-Back systems on the 6.uh oh's are easy to swap... IMHO just buy the exhaust you really want an dont sweat it.. magnusson-miss act says they cant void warranty from aftermarket parts anyways... they just wont cover the exhaust if it in itself malfunctions
Beware!!!! The King Has Returned
DunesRunner08 is offline
post #10 of 20 Old 09-13-2013, 01:42 PM
Quoted: 8 Post(s)
Can you elaborate more on this? So many people have been refused warranties just because of CAI kits... Definitely watching this
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
